Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Water not making completely through the heads to exhaust
Hello, My 130hp yamaha 2-stoke motor heat sensor went off while running today, water pump working great pissing but not exiting the heads to the exhaust, Pull thermostats to see if working. no problenm there. What area could be blocked? All was working well two months ago.
Thanks Clif
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
Heads could be clogged with corrosionor sand.
Posted on Oct 12, 2010
Have a 2 stroke 225 Yamaha outboard. Alarm for what I can tell for heat, an oil went off today. Runs fine at lower rpm, but goes off when it goes up beyond 21 rpm.
How long has it been since you changed your water pump? The pressure relief valve can also cause over heat issues if it is stuck.
May 12, 2017 | Yamaha Boating
Need to find a lower unit for a 30hp 2 stoke 3 Cylinder yamaha boat motor 501 2841100 casey
30hp 2 stoke 3 Cylinder yamaha Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Yamaha Complete Outboard Lower Units
Kijiji Canada
Automotive Parts Accessories Boat Parts Outboard Engines Components...
Mar 24, 2016 | Boating
My yamaha tdr 125 keeps over heating. put new thermostat in plus temperature sensor, water pump is all workin, pipes are all clear, had new gaskets, piston, piston rings the lot done to it but it keeps...
Hi, Ally and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.yamaha-motor.com/assets/service/manuals/2007/LIT-11626-20-01_ttr125all_1961.pdf
OEM parts for Yamaha
YAMAHA TDR125 Owner Manual
Yamaha TDR 125 2001
Tips Tricks
Dec 17, 2011 | 2000 Yamaha TDR 125
I have the 1998 Lincoln Mark VIII with Over Heating Problem. I replaced Sensor which had low input and Thermostat. You stated that I have Blown Head Gasket. (emissionwiz) Would the motor run rough is this...
You should have found the oil floating on the top of the radiator, A compression check will tell you real fast if the head is blown and even tell you which piston it is, The exhaust should have steam in it. Hope this helps.
Aug 25, 2010 | Lincoln Mark VIII Cars & Trucks
2001 xlt1200 exhaust warning
Try flushing the engine out with fresh water,on land, to see if sensor trips alarm.Make sure your water lines coming from the rear pump are not clogged.
Aug 04, 2009 | Yamaha 12V Air Pump
I have a 01 Jetta, the car is overheating while driving
yes it sounds like the water pump to me.$400 is quite expensive i would have thought.Get anouther quote for the job.good luck.
Aug 02, 2009 | 1998 Volkswagen Jetta
Running hot coolent is fine...
check for a blown head gasket it will sometimes pump air into the heads and make the coolant levels seem fine but in truth they are not and check the water pump for rusted fins make shure the water level sucks down during sharp throtteling of the motor if so the cooling system is fine as far as that goes but where to start
1.) tempature switch located on the motor it tells the ecu when to kick on the cooling fan
2.) fans spin freely without taking force
3.) thermostat it could be stuck closed due to someone at sometime only running water without antifreez and causing the pressure pin to rust and freeze the gate shut
4.) monitor the water levels if they go down suddenly as 1 gallon of water a week or 2 weeks its a bad head gasket you can see this on spark plugs as well
and for most your water pump make shure you get good heat from the heater at low running tempatures and start the car and monitor what the water in the radiator does (while its cold) the water in a car is over 195% and can easily do harm if the car is just warmed up not even close to over heating so you can imagine what it could do at an over heated state
but get the problem fixed or else you can result in blown head gaskets water in the oil piston breakdown do to rust in the piston walls and even worse complete engine failure
Jul 16, 2009 | 2002 Chevrolet Impala
My yamaha 130hp outboard starts and runs good but
The carbs need to be cleaned.There is a high speed jet in the carb that is more than likely stopped up. Jim OMC retired mech.
Jul 07, 2009 | Boating
Cooling system outboard
Sounds like you burned up the impeller on the water pump. You will need a replacement part and when you install it, do not run the motor out of the water. You will be lucky no other damage was done.
May 10, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
210 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
