Question about Hoover 24 in. DT999 Free-Standing Dishwasher
Hoover DT999 - Jammed Door
I can only open the door half way. It feels like it is stuck on something and I don't want to force it. Can I take the door off easily to try to fix it?
  • 49 Answers
No. you dont want to take the door off. 1st thing to do is take off the side panels for access to door hinges and you should be able to see what is going wrong.
p.s. take the top panel off first before removing the side panels
Posted on Feb 19, 2008
  • Michael Taylor
    Michael Taylor Feb 05, 2014
    Great found that spring had broken now to and try get a new one Thanks
Hi I have an iseo lock on my reasonably new summerhouse and although i have the key and the key turns both ways in the lock, apparently engaging and disengaging the lock on a single turn each way, i cannot...
You should be able to feel the lock disengage. Also feel the latch moving. If you can feel this, then the door is jammed, not the lock or handle. They do swell. You'll just have to force it open. You might try spraying some lube at the top and bottom, where you suggested it feels stuck.
Mar 01, 2015 | Cars & Trucks
Dodge caravan sliding door
be looking at the control relay switches for that door..also look for the door to be off track,, this may be putting it in a bind..
Dec 23, 2013 | 2008 Dodge Grand Caravan
2000 Toyota Sienna power sliding door is jammed shut. Any solution?
Open the inside panel of the door by popping off the little white clips holding it on. The cable connected to the inside release button is either caught on something or has come lose. Check out this video - https://www.youtube.com/watch?v=MkC2OiOiE_U
Jun 10, 2017 | 2000 Toyota Sienna
How do I fit a new door gasket to a Hoover DT999 dishwasher (the short horizontal seal at the bottom of the door, not the longer one which wraps around the inside of the body of the machine)?
Well I just did this (ew!)
basically it just pulls out of a slot downwards (when doors open) but there's not much space so I took out a few screws to free the door up a bit.
So - sitting with the machine in front of you and door open down towards you:
I took out the two machine screws that hold the door on to the spring/hinge mechanism. Those are the two on the side of the door near to the hinge/bottom.
I also took out 3 of the screws that screw the inside metal bit of the door on to the plastic fron of the door.
You'll notice that the springs then force the inside and outside of the door apart and you've got some free space to pull the bottom seal out of the metal door. Then clean everything and squeeze the new seal in.
You're probably not going to be able to thread it in from one end.
When you're putting those two machine screws back in you'll probably need to do the top screw (nearest you when door open) with the door almost closed so that the spring is most relaxed and will let you line up the two holes.
Hope that helps
Dec 16, 2010 | Hoover 24 in. DT999 Free-Standing...
Sears garage opener opens back up when half way down
increase down force, especially if you are in a cold climate. turn to increase down force a little. test door to see if it reverses upon hitting something w/o too much force.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
F & P dishwasher 913T/87198 - ? how to replace door springs
I have done this on another make, but most front loading are very similar see pictures and solution here:
http://www.howtofixanything.co.uk/howto-260.html
Jan 12, 2009 | Hoover 24 in. DT999 Free-Standing...
Hoover Washing M/C Door Jammed
we had the same problem on ours, a techy came out to it and hit the washer above and the the right of the door handle, and hey presto the door opened, have done this myself since, works everytime
Nov 03, 2008 | Hoover AAA160 Front Load Washer
Hoover Washing Machine Door wont open. Please help the door opener feels slack! How do I get it to open. Its a hoover nextra. Thanks Lisa
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Aug 05, 2008 | Hoover Washing Machines
Wahing machine Tricity Bedix AW1260W-Door problem
probably handle mechanism broken. to open is a bit difficult.
disconnect from mains and take top off.
feel down the cabinet front on the side where the door handle and opposite the door handle you will find the door interlock. in the door interlock, you will find the end of the door peg. force this towards the middle of the machine and with luck the door will open.
anothetr method is to break the handle off and use a small screwdriver on the door peg
Jul 21, 2008 | Tricity Bendix AW1200 Front Load Washer
Hoover 24 in. DT999 Free-Standing Dishwasher Logo
111 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
