Question about Refrigerators
I have a magic chef compact refrigerator model mcbr445b1 wont turn on dont remember how to reset it with red button on temperture dial
  • 619 Answers
Sounds like defrost timer on back right corner has stopped in the defrost position. Located bottom left corner inside white plastic box if you are behind ref.
Posted on Feb 01, 2010
I have a small magic chef fridge that just stopped working. Can seem to get the motor going at all - if just defrosted by itself. Inside is a dial and a red button - we've clicked that a few times to try...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Magic Chef MCBR445S1 Stainless Steel...
Magic Chef Refrig Model MCBR445B1, the motor/fan/compressor is not running when plugged in.. It is approx. 5 years old. Is it worth repairing?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 24, 2010 | Magic Chef MCBR440 Compact Refrigerator
How do I set the temperature?
Hello Elise, The Dial should be set to the middle number three (3) to start with and allow for 24 hours of running before you make any adjustments, either up or down.
The higher the number the colder the fridge temperature will be. Just remember that it takes almost a full day for the fridge compensate for any changes to the thermostat. Also, only make adjustments in the temperature setting by only 1 increment at a time (either up or down) and again, allow 24 hours before making further changes.
If your fridge has the red button in the center of the temperature dial, that is the manual defrost button. So if you've got a build up of ice on the freezer section, just push it and it will defrost the unit for up 2-4 hours.
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 14, 2009 | Magic Chef MCBR440 Compact Refrigerator
Our compact refrigerator doesn't get very cold,
One is the coldest. Post a model number and I may can help more. If it's a manual defrost then defrost it. If it's auto defrost- If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 11, 2009 | Refrigerators
Not cooling
From my earlier post, our compact Magic Chef 'frig was not running at all.  It still looks perfect, so decided to check on the repair.  It turned out to be the "starter switch," I think is what the switch was called.  The repairman said this is a very common problem, so he had the switch we needed in his truck.  It was repaired quickly and is running great.
Cost was about $140, part plus labor.  A replacement would have been only a few dollars more, but would take more time and effort.  FYI, the compressor on these Magic Chef refrigerators has a 5-yr warranty.
Hope that helps someone. Jaci
Mar 01, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic chef compact fridgerator model mcbr445b1
you may just have a bad relay. with the power removed ..(unpluged)
remove the relay cover ( on the side of the compressor)
remove overload and relay
check relay for 4-5 ohms
check overload (if open it is bad)
let me know
Dec 21, 2008 | Refrigerators
Tried to lower temp...but it raised instead...can't figure it out
My daughter has an MCBR445w1, probably a similar size dorm refrigerator. It has died. I brought it home tonight to try and get it repaired. The red button in the center of the thermostat dial defrosts the unit. That's why you got the flood. On her unit, 1 is the warmest, 7 is the coldest. I'd turn it to 7 and see what happens. Keep dust off the coils if they are exposed.
I have a feeling these units are just bad refrigerators, but I will try and get hers running. Good luck with yours.
Mar 01, 2008 | Magic Chef MCBR440 Compact Refrigerator
Refrigerators Logo
912 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
