Question about Canon EOS Rebel G 35mm SLR Camera
I cannot get my camera to take a picture. I just put a new roll of film in it, but it will not work.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
What is not working? Is it not turning on? Is the meter not working? Is the film not advancing? Is the flash not flashing?
Posted on Feb 01, 2010
Minolta300 si new roll of film put in tzke a picture counter jumps from 1-15 what causes this?
possible that the counter is not reset after putting the new roll of film in the camera
Jan 06, 2016 | Photography
I just put in a new roll of film and I took 3 pictures and then the screen at the top said "ERR" and the film retracted itself....what happened?!
Hi, On Minolta's ERR means that the film hasn't been loaded in the camera properly so you'll want to reload the film.
Jun 15, 2011 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Do i need to rewind film after taking a picture on my diana f+ ??
If you are using 120 film (medium format) you only need to advance the film as far as possible. Then remove the film from the camera and wrap the excess paper around the roll and seal.
When you finish all the pictures on the roll of 35mm film you will need to rewind the film completely before exposing it to light. You can do this by taking the camera in a pitch dark room, removing the film and turning the knob on the top of the film roll until the film has been completely wound back into the the roll.
Mar 29, 2011 | Lomo Diana F+ 35mm Film Camera
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
Auto rewind on my Minolta camera
Broken gears in Advance Assembly.
Needs service.
Mar 22, 2009 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Nexia Q1 is flashing low battery when i put in brand new ones
Use alkaline batteries or rechargeable ones with over 1000mA
Dec 29, 2008 | Fuji Nexia Q1 APS Point and Shoot Camera
Bad film or Camera.
Return the camera to the company and see if you can get a return or at least an even exchange. Get another roll of film and shoot casual stuff. Never test a camera, film or digital for the first time at any mission critical event like an anniversary or wedding. It can lead to potential disaster. Shoot the roll with the new camera if you got it exchanged and then have it developed at Walmart or wherever is cheapest. If it works, keep it. If not, don't. BTW, if you are ever going to have to shoot a wedding or anything ever again with a film point and shoot and don't want hassles, just get disposable cameras. They are designed to work out of the box with no problems. They are of higher quality then most people think for image qulity.
Polaroid used to make good instant cameras, but their 35mm film and digital stuff I wouldn't trust as much. It's not the real Polaroid which can makes only instant film gear. . It's another company using the Polaroid brand name to try and make otherwise generic stuff look better then it is. Their digital cameras have a poor reputation. I don't think their non instant film cameras are much better. Good luck.
Apr 08, 2008 | Photography
My minolta sightseen camera wont take pictures?
The blinking zero would indicate that the film has not loaded but the cartridge is in place. The camera won't do anything when this occurs. Try opening the film door and load the roll again
Jan 14, 2008 | Photography
Auto rewind going crazy
clean the contact terminals inside the film compartment. Your camera has an abnormal autorewind switch detection.
Jan 09, 2007 | Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
Canon EOS Rebel G 35mm SLR Camera Logo
75 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
