Question about Dryers
The dryer runs fine but produces no heat. Multimeter readings at the heating element seem normal.
    President:
  • 2,468 Answers
Check the cycling switch,the hi-limit switch and the cutout switch all located on or near the element case,all items have control over the elements heating or the complete shut down of the element to prevent fire
Posted on Feb 01, 2010
Estate Dryer TEDS840PQ0 stopped heating. Is there a fuse or is it a bad heating element?
But its running right? just not heating? if not running u may have bad motor windings, other wise check out the thermistor, and other thermostats and the element with a multimeter, if u get no continuity on ur heating element ? ITS BADDDDDDD SHOULD READ BOUT 1200 OHMS
Sep 14, 2014 | Dryers
Dryer does not heat. Motor and fan work fine.
is there a reset button on your element that needs to be pressed in have you checked the voltage going to element might be pc.board
Apr 05, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
Dryer runs but does not heat.
Hi.
Check the thermal fuse. The fuse can be tested reading impedance.You can replace the fuse straight away, or you can first test it using a multimeter set on Ohms. If the multimeter reads Ohms infinity when you touch the fuse contacts with the probes, then the fuse is gone. A good fuse will read zero or low impedance.
If the fuse is OK, then you can have a defective thermostat.
In the same way you test the thermostats, thermistors or cutoff located in the heating group, near to fan and element. If they are OK, then they will be conductive at room temperature and will read zero Ohms. If they are bad they read open (infinity). You need to disconnect the part's contact to test properly.
The rest depends if the dryer is electric or gas.
On electric dryers you test the heating element. The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most washer-dryers, including Whirlpool and Maytag read between 10 and 20 Ohms.
With gas appliances you need to test the ignitor, then coils and then the flame sensor. The ignitor is the most common cause for the problem. Heating coils problems are also common. The flame sensor does not fail very often.
Regards.
Ginko
Sep 06, 2011 | GE Dryers
I have a Whirlpool electric dryer MOD WED5540S!) SER MU2124790 TYPE DWJR-ELE-2406026-FM54 the dryer runs good, but will not heat. I have checked the air flow and its clear. I've checked all...
Limit thermostat , heres how you check thermostats Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Whirlpool WED5500S Electric Dryer
Dryer want heat up what's problem
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it. Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryerOnce you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it, thanks to parts direct
May 31, 2011 | Maytag Neptune MDE6800 Electric Dryer
Heating element replaced. Worked one load and back or dryer seemed very hot. Turned off and later ran on low. Next load no heat.
Hi.
There is either a problem with the thermostats that turn off the heating element, or the heating element is plugged (elements has contact to ground and stays always on).
Heating element and thermostats are tested reading Ohms with a multimeter set at Rx1. If the circuit is open (Ohms stay infinite), then the part is defective.
If the machine overheated, then the element may be gone again. Test reading Ohms.
Also replace the thermostats (there should be two or three of them), unless the element had a contact, the most common cause for overheating is a shorted thermostat.
Aug 04, 2010 | EuroTech EDC158 Electric Dryer
Dryer will not run or heat
Could be the thermostat or element....Element should read around 32 ohms on multimeter..stat closed circuit.....Try to look for any overheat cut off at the back anywhere...
Apr 12, 2010 | Maytag PYE2300AY Electric Dryer
My dryer will not heat up
hi friend,
Step 1 The most common cause of a dryer not heating is that the air duct gets clogged. This can cause a fire and should be cleaned out about once every couple of months. Take the air duct off from behind the dryer with a screwdriver and take the other end off near where it goes into the wall. Run a hose through the air duct until all the junk and lint from inside gets out. Let it sit in the sun for about an hour to dry then hook it back up. Try the dryer out to see if it heats again.
  • Step 2dryerrepair_thumb.jpg Dryer thermostat The dryer's thermostat can also be the cause of it not heating. Locate your dryer's thermostat and take it out with a screwdriver. Take your multimeter and set it to the resistance setting. Put one lead on each terminal. You should get a reading of 0, or -1, which means infinity. Any other reading than this means the dryer's thermostat is bad.
  • Step 3dryerheatingelement_thumb.jpg Next, test your dryer's heating element. Heating elements cary in what they look like but you should see some sort of coil of wire like a toaster. You can do a search online for your dryer's heating element. Once again, set your multimeter to resistance and take the heating element out. Put one lead of the multimeter onto each terminal of the heating element. You want a reading that is not 0 or -1. If you get a 0 or -1 your dryer's heating element is bad.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Try walking into your local hardware store and asking them if you get stuck.
    • Make sure you un[plug the dryer before you start to fix or repair it.
    hope this helps u
    please rate me..................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Dryers
    Maytag MDE6700AYW Electric Dryer Error Code "he"
    Could be the thermistor, or the element, or the control board. You have to use a multimeter to troubleshoot the problem. You unplug the dryer, disconnect the element and use an ohmmeter to test the element for continuity.
    If you don't have a multimeter, you could replace parts randomly to see if you can find the problem
    Jun 29, 2009 | Maytag PYE2300AY Electric Dryer
    Kenmore Elite dryer won't heat but otherwise operates normally
    Make sure you have 220V. The dryer will work (no heat) if only getting 110V. Check your thermostats with your Ohm meter. Mkae sure plug is disconnected and you disconnect thermostat wires. Should have continuity. Just because you have checked your heating element and you have continuity that does not mean it is good. How can this be? Easy, sometimes they (coil in heating element) break and arch against the housing or ceramic insualtors (depending on model) and you will have continuity. This just happened to mine and without a visual inpsection of the heating element do not aaume it is good.
    Jan 07, 2009 | Kenmore Elite HE4 Electric Dryer
    Dryers Logo
    64 people viewed this question
    Top Dryers Experts
