Question about Samsung (SD-612) Internal DVD Drive
I have toyota prius, As I start car, master warning light, dischrge warning light, ign and malfunction indicator light come. what do i do to fix these problems?
  • rgrover Feb 04, 2010
    Re Toyota PRIUS 2000.
    while driving Hybrid System Warning light (small battery sign), Master Warning light (Triangle with exlaimation mark) and sometimes Malfunction indicator lamp and Brake system warning light comes in.
    I had the diagnositic test done and have removed /erased some errors but the problem has come back
    I was told by the very experienced car dealer today who has sold many PRIUS cars, that I should just chnage the small 12V Battery and go for along drive. All will be well.
    Can anybody help
    Genius:
  • 1,341 Answers
Your car is reading errors from different source and the best and most effective way to tackle this is to start by having a diagnosis test on it.It consist of a connection connected to a computer which will then read and allow you to erase/reset or read error codes.Once you get the codes then you know where to start looking.Hope this helps.
Posted on Feb 01, 2010
2008 Prius, malfunction Indicator Light is on. Why? Possible fixes, costs??
Check your hybrid drive coolant reservoir for coolant level. top off if needed using only Toyota coolant. Also common for the auxiliary water pump to fail. I think there is a recall free replacement. Check with your dealer if your car is included in recall.
Nov 17, 2017 | 2008 Toyota Prius
ABS ON,BRAKE RED L ON ALARM ON HARD PEDAL HOW CAN I FIND THE PROBLEM
VSC ABS and ! lights plus red (!) - Toyota Prius Forum ...
www.priusonline.com/...toyota-prius.../19804-vsc-abs-lights-plus-red.ht...
Jun 3, 2008 - 8 posts - ‎3 authors
If the accumulator fails, you will get a red brake warning light and the pump will now run continuosly until it burns out. ... hydraulic pressure to the brake system and "no"red warning lights. .... Fog Lights, PassGas, Toyota Prius General Discussion, 4, 10-13-2005 09:12 AM ... 11-13-2015 10:01 PM by Tim Lee.
Alarm with Brake Light, ABS, VSC and amber warning lights ' PriusChat
priuschat.com > ... > Gen 2 Prius Care, Maintenance and Troubleshooting
Jul 26, 2005 - Later that same day - I started getting an alarm - as soon... ... Gen 2 (2004-2009) Toyota Prius Forums > Gen 2 Prius Care, ... Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by NorthStar, Jul 26, 2005. ... I am getting the red BRAKE LIGHT, the amber waming symbol, ABS, and ... VSC, ABS, (!) and emergency brake light on
Feb 5, 2010
Brake, Brake warning, ABS, VSC appear
Oct 5, 2008
More results from priuschat.com
Nov 24, 2015 | 2005 Toyota Prius
Exclamation light on
It means Master Warning Light. It illuminates when there is any malfunction in the engine and/or the hybrid system of the vehicle. When the master warning light illuminates, it become necessary to get the car be scanned thoroughly for malfunctions.
Aug 22, 2014 | 2005 Toyota Prius
My 2007 prius will not start.
Scan the car and locate the problem.
Aug 03, 2014 | 2007 Toyota Prius Hybrid
Prius 2005 triangle indication
The Triangle indication:
Description: MASTER WARNING LIGHT.
The battery ECU has a self-diagnosis system. If the computer, High Voltage (HV) battery system or the components are not working properly, the ECU carries out a diagnosis to detect the malfunction, and illuminates the master warning light in the combination meter together with the HV system warning indicator on the multi information display.
NOTE:
The master warning light illuminates when the HV battery system fails and it blinks when in inspection mode.
Apr 17, 2014 | 2006 Toyota Prius
How do I turn off master warning light on 2005 toyota prius
You need a scan tool or a code reader to do it but,if the problem still exists then the lights will come back on.You need to retreive the troubles codes from the computer to see what area of the engine that problem exists and go from there.
Oct 18, 2012 | 2005 Toyota Prius
I have a red triangle with ! inside it and red car with ! in the middle of it , so please i want to know this error in Toyota Prius 2008
This the hybrid master warning light, which means the system has detected a malfunction, there are many causes that turn the light on, there are about 24 computers involved, the best advise I can come up with is that you have the toyota dealer check this and diagnose it, this may also still be under the powertrain or hybrid vehicle warranty
Aug 21, 2011 | 2008 Toyota Prius
What does the master warning light mean? (triangel with ! and the three lights points to the car).
This light shows operational status of traction control system. If it is constantly lit when engine is running, this means that traction control system is off. If the light flashes during driving, it means the loss of traction at the wheels, and traction control system is operating- decreasing engine torque to stop exessive wheelspin.
Good luck.
Mar 21, 2010 | 2003 Toyota Prius
Warning lights
On a Prius, when the check engine light comes on it indicates a malfunction in the powertrain control system. You need to have the car scanned for codes to see where the fault lies. The red triangle lights because the check engine light is on. The VSC is disabled when the check engine light is on and that light comes on.
Start with having the car scanned.
May 14, 2009 | 2008 Toyota Prius
Master warning light
check all 5 doors for closure, the rear hatch usually has the carpet stuck in it.
Jul 16, 2008 | 2008 Toyota Prius
Samsung (SD-612) Internal DVD Drive Logo
159 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
