Question about Legacy Interactive Video Game Consoles & Games
Cannot activate plunger and therefore can go no further to solve
Murder She Wrote A Deadly Catch cannot drain the sink have tried to put plunger in, above and under sink - hint just circles the plunger - help!!!
  • pamrowett Feb 01, 2010
    Tried clicking on the water but all I get is a message saying "It looks like his sink is clogged. We should see if we can fix that for him while4 we're here" and the drain does not become unclogged. When I try to put the plunger in or near the sink it just reverts to its position on the floor - it's got me stumped!!!!
  • pamrowett Feb 02, 2010
    Murder She Wrote A Deadly Catch - Cannot drain the sink. Have assembled plunger and tried to put it in the sink but it keeps returning to the original place. When putting the arrow on the sink it comes up with a message to say the sink is clogged and we should fix it but cannot unclog it it's very frustrating!!!!!!!!
  • 506 Answers
Check this nice little walkthrough out for your game. The plunger detail is located about halfway down.
http://www.gamezebo.com/games/murder-she-wrote/tips-tricks/murder-she-wrote-walkthrough
Posted on Feb 03, 2010
  • 324 Answers
Regarding the plunger issue, once you have the stick and the base of the plunger put together, you need to click with your arrow pointer on the water in the sink, not with the plunger base. That will get it to work.
if I have helped you please vote :) thanks
Posted on Feb 01, 2010
    Guru:
  • 194 Answers
Hello pamrowett
You need to assemble both the stick and the plunger head together. You then click on the water that is in the sink with the arrow. That should work. Please let me know if you are still having problems.
Kind Regards
Stephan
Shower and bath sink wont drain.
Bath sink will be on what is called a "wet vent" for the shower.
That means they are on the same drain.
There should be a cleanout on the sink drain below where the drain enters the wall. That would be your "last resort" access to put a snake in to break up the obstruction.
I would try using a plumbers suction plunger on the shower drain.
Show no mercy!
Cheers.
Reply as a comment to this post.
I'm a retired plumbing inspector so should be able to coach you.
Oct 24, 2015 | Dishwashers
I have a glass bowl sink in my bathroom. The pop-up drain is stuck in the down position and will not release. How do I fix it??
You'll need to access back side of sink bowl and locate drain mechanism, most likely either the plunger rod has loosened up from clevis rod or clevis rod is positioned to far in towards drain line causing it to bind. Check diagram for assistance in locating parts.
Is the plunger rod tight or loose? You can also loosen clevis screw and see if the plunger rod will slide freely. If it does try moving the horizontal pivot rod up and down, while doing this you should she your drain plunger moving up and down. If it does not then most likely will need to replace plunger mechanism by removing the retaining nut on the back side of the drain line. This will allow you to disassemble the actual drain plunger but I would definitely start with the mechanism of the stopper and clevis where it attaches to horizontal rod.
Sounds like a simple binding. Always be sure there isn't anything stored under your sink which could be causing the problem. Sometimes the most obvious is the last thing we look at.
Good luck.
Aug 16, 2013 | Pegasus Technologies Pegasus Clear Round...
Garbage disposal and possible clogged drain
plug the one side of the sink so as to create a sealed enviroment for the plunger to work weffectively ... plung the open side ..
If this does not work , try running a metal coat hanger thru the outlet at the disposal exhaust line.
Mar 25, 2013 | Electrical Supplies
The cable system on the pop up assembly is not working. lifting up or pushing down on the stem does not engage the plunger(in the sink drain).
One of two things can be wrong.The first is the drain plug itself has become disengaged with the plunger inside the drain line. You can check this by pulling up on the drain stopper itself, if it comes all the way out then all you need to do is to reinsert it and give it a little twist to get it reseated on the plunger hook. The other may be the drain handle on the top of the faucet may be disconnected from the rod. Open up the doors underneath the sink and inspect it. The rod should go down and the plunger handle should connect to the rod via a bent metal clip. Ensure it is in the correct position to activate the handle in the drain pipe when the top is pulled up.
Nov 29, 2010 | American Standard Swan 4 In. Bathroom...
I put half a small lemon down the garbage disposal. The disposal kept working fine with the water running, but then it violently threw out water and food particles. I stopped the disposal immediately, the...
Sounds like a clog at or beyond the P trap of the sinks. With water coming back into the sinks, it has to be part of the drain line that is common to both sinks. If you try and unclog the sink, work on the side that does NOT have the garbage disposal in it. A small hand snake for sinks might do the job. You could also try a plunger on either side, but when you do, put a wet rag over the other drain so you are not just pushing air back and forth. Work on one side with the plunger while holding the wet towel down tight over the other drain. Sounds like a clog that was there prior to you putting the lemon in the GD.
Oct 02, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you secure the overflow plate
I think you're referring to the drain stopper in your sink? They have to positions, one drop in so you can remove it easily to remove debris, or the other position it is engaged in the lever assembly that raises and lowers it. Loosen the nut on the drain line where the lever enters the drain (under the sink) retract the lever slightly, lower the plunger with the hole aligned to the lever. Re-insert the lever and test that it raises and lowers the plunger. Then try to lift the plunger. If you have engaged the lever into the plunger then it will not come out. Re-tighten the nut.
Jul 04, 2010 | Moen 103459 Drain Pop-UP Plug
How do I unclog my kitchen sink drain?
easy go get a coat hanger and run it down the drain into the trap and try to pull up whater is clogging it or use a plunger.
Jun 03, 2010 | 2000 Ford Taurus
Slow draining kitchen sink
Yes, if you had any sort of blockage that kept the water from flowing out, it would accumulate in the drain pipe and once freezing temps showed up, it most likely froze. You might try putting as much HOT water down the drain as you can to defrost the pipe and then try you plunger or auger.
A professional drain cleaning company could probably solve the problem much quicker if time is an issue for you.
Jan 09, 2010 | Computers & Internet
My sink is backing up on bothe sides
Your drain line is clogged, beyond the sinks. You might be able to use a plunger to clear it. Seal off one the drains and use the plunger in the other. After you get it cleared, run pure hot water for a few minutes to melt the junk out of the line. When using the disposer, use cold water only, NEVER hot. If this doesn't get your drain flowing, you will have to snake the drain--to the main drain.
Oct 04, 2009 | Home
Clogged sink after using garbage disposal
You have a clogged trap. Try a plunger, draino or disconnect the trap and clean it
Mar 15, 2009 | Home
Video Game Consoles & Games Logo
91 people viewed this question
Top Legacy Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Legacy Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
