Question about Toshiba Computers & Internet
Wont start up easily
Using Windows XP - seems to have tough time starting up from being turned off. Seems to be in a standby mode ?
    Genius:
  • 1,189 Answers
This problem can be cause by, too many Start-up Programs opening when the Computer Boot-up. Open the Control Panel, click on Programs, and open ("Change Startup Programs").
Posted on Feb 02, 2010
Dell pc with windows xp wont come out of standby mode to be able to power up pc and use it
First, how do you know it's in standby mode?
I would turn it off and disconnect from the power source. Then plug it back in and try to start it. If possible, start it in safe mode to see if you can identify what is happening. If in safe mode, do a system restore back a day or two.
var fctb_tool=null; function FCTB_Init_889fec04667049cfad3405862ebb395a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d9758fe2c8fa4d33bc34f8b0b6f0496c(t) { fctb_tool=t; start(fctb_tool); }
Jan 02, 2011 | Microsoft Windows XP Home Edition
System defaults to "Automatically fix file system errors"
Open my computer and right click on your local drive click properties click tools click check now remove check from Automatic fix file system errors start same with the more drives
Jul 04, 2010 | Sony Computers & Internet
Can only start pc in safe mode keeps doing windows inconsistency check. Seems to be on loop. Blue screen shows Tech info stop 0X0000007F (0X0000000D, 0X00000000, 0X00000000, 0X0000000. Windows XP. Please...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 15, 2010 | Computers & Internet
My 2002 Jetta TDI seems to be having a tough time
yes glow plugs have a lot to do with engine having tough
time in cold weather. before replacing glow plugs
check relay and fuses.
Nov 14, 2009 | 2002 Volkswagen Jetta TDI
Installed SH-S202 dvd writer some time ago, and since that time have experienced shut down problems on my Dell with XP pro. It never shuts down, but seems to go into Standby mode first. Then, when it...
Check the power settings:
START | Control panel | Power settings
Make sure all settings are Never
Also go to the Advanced tab and remove any Standby entries.
The DVD Writer installation is most likely a coincidence then an actual suspect with the standby issues.
Thanks,
Vincent
Nov 21, 2008 | Computers & Internet
CAN I RUN MSWINDOWS XP SP2 ON THIS MS7308E BOARD
not much choice here. seems like the Windows Xp operating system having probelm itself.
re-install Windows Xp. then you can go on the internet and download the driver file you need.
first thing first.
Oct 14, 2008 | Matsonic MS7308E (MBMS7308E) Motherboard
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
LCD problem
ok just go to Start- Settings -Control Panel - Power options -click on it inside that turn off monitor option Never u say and system stand by u make it as Never apply and say ok it will not go to stand by mode
Jul 30, 2008 | Computers & Internet
Xp blue and black screen
It seems like you had a software conflict...
Jan 12, 2008 | Microsoft Windows Xp Home Edition English...
Boot failure pentium 4
here is a temporary fix, but you may like it as a permanent one. Use the Windows hibernate mode. It actually works every time! Windows makes a "System screen shot" and stores it on hard drive and then powers off. Just be aware that you must ensure enough hard drive space for this. I am using this mode every day now. I think your system is trying to reject the power-saving features selected in Windows or at CMOS settings. Try turning off (or disabling) one feature at a time. I still think hibernate is the way to go. Here is a useful tip: to force hibernate (after it has been enabled) select START-SHUT DOWN and hover over STANDBY button and then hit the SHIFT key. The STANDBY button will turn into the HIBERNATE button. This is a quick way to enter hibernate. Remember to enable SYSTEM RESTORE mode so that if anything goes wrong during this "experiment", you can easily restore Windows system. I also use RESTORE but I also "clean house" once a month by turning it off and Disk scan and defrag and turning it back on.
Jun 24, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
