Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Focus is out - Hitachi 57F500 57" Rear Projection HDTV-Ready Television
  • 135 Answers
Is it focus or convergence? When the convergence goes out the flash focus will not work properly
Posted on Feb 01, 2010
While driving my 2012 Ford Focus it acted like it was in neutral when it was actually in drive I pulled over put it in park and the motor quit and now won't even turn over
2012 Ford Focus Recalls - Cars.com
www.cars.com/recalls/ford/focus/2012/
Cars.comLook up all NHTSA vehicle safety recalls for your 2012 Ford Focus, and contact a nearby service center for free repairs.
2012 Ford Focus Problems, Defects & Complaints
www.carcomplaints.com/Ford/Focus/2012/
The 2012 Ford Focus has 1605 problems & defects reported by Focus owners. ...October 28: Ford Recalls 131,000 Vehicles, Mostly SUVs For Fire Risk ...Transmission - ‎Focus Recalls 3 - ‎TSBs - ‎AC / heater
Nov 08, 2015 | Ford Cars & Trucks
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
My cable release is not working. It triggers the auto focus but will not take a picture.
Try setting the camera to M manual focus and manually focusing on the subject. Some combination of focus size and focus type may not focus unless the sensor sees a subject and is in focus. So if the sensor cannot see and know it is in focus it will not fire. If you subject is not moving then focusing in manual will ensure the subject is in focus and the camera can shoot.
Apr 10, 2010 | Nikon D300 Body Only Digital Camera
Is the focus area switchable?
The focus area can be set for Wide Focus Area or Spot Focus Point. When selecting the Spot Focus Point, the DiMAGE A1 can be set "Flex Focus Point (FFP) ".
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
The focus area can be set for Wide Focus Area, or Spot Focus Point. When using the Spot Focus Point, the DiMAGE 7i offers "Flex Focus Point (FFP) " for controlling the position of the Spot Focus Point. This is a powerful tool for off-center subjects.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Manual Focus
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button. 2) Press and Hold the DISP/i button to see the Manual Focus Range. 3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key. 4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture. *Press the Focus Button to return to Auto Focus / Macro options
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Manual focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
