Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
Black lines through documents
Hello, every time a page is scanned or copied it comes out with two fat black lines through the document. What can I do to fix this???
  • 2 more comments
  • Anonymous Mar 04, 2008
    black line in document
  • red hat girl Aug 21, 2008
    1. every time I scan a thick black line prints on right side of copy all the way down the page. Please help!!
  • jlokjlok Sep 30, 2008
    I got the same problem on this 2.5 years old printer. The regular printing is fine, that I believe it is the problem on the scanner
  • gene424 Nov 08, 2008
    My HP 2575 all-in-one prints fine, but when I try to copy or scan there is a black line from top to bottom about 1/2 inch wide on top of the scanned material.
When printing from the printer we have 2 black lines. It prints fine from the computer. How do I get the black lines to go away?
Posted on Sep 28, 2008
Try cleaning the cartridges to see if that helps..... mine did the same thing and after I cleaned it, it worked like new.
Posted on Aug 11, 2008
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
When I scan my documents there's a black line that appears down the pages. How do I fix it?
This is usually caused by something on the image scanner glass. Check out this page.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, if so please rate our solution.
BuddyMc
Mar 22, 2011 | Office Equipment & Supplies
When scanning or copying a document it prints a black page
IN NO TIME AT ALL, YOU WILL RUN OUT OF INK.
SUGGEST YOU REMOVE PROG RESTART, THEN SETUP AGAIN. GLITCH?
Nov 15, 2009 | Dell V305w All-In-One R840635AU InkJet...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Photosmart C3180 not copying properly
mke sure there is no sticky tape on your inkjets
Apr 20, 2009 | HP Photosmart C3180 All-In-One InkJet...
Black streak down side when making a copy
Hello sir; I believe you need to replace drum cleaning blade.
Mar 12, 2009 | HP Office Equipment & Supplies
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
1,009 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
