Back to:
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
posted by DONK 47 on Feb 18, 2008
NEED TO ENTER THE CODE INTO MY SKY REMOTE FOR MY LINK UPSTAIRS. HAVE TRIED KNOWN CODES, THIS MUST BE NEW
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 18, 2008
Not Rated (0)
avid_imps
Rank:Guru Guru
Rating: 87%, 293 votes
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
AOC A15X221 15 in. LCD Television
I have a Compaq computer running XP. Recently I installed...
RCA L32WD12 32 in. HDTV LCD Television
I have had this tv for almost 2 years, recently I turn on...
phillips 47 inch ambilight t.v perfect picture and sound...
Syntax LT26HVE 26 in. HDTV-Ready LCD...
I need a remote code for a Syntax LT26HVE. It is not...
i get no visual on tv yhe monitor keep sayin no signal
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
