Question about Ironman Exercise & Fitness
I have an ironman edge treadmilll. when i switch it on it is not running. i try calibrating it. i see cl26, speed is 28.5 and inclination is 28.5 but nothing happens.
  • 10,515 Answers
The single most cause of no motor output is failure of the DC motor control. Before you attempt to determine if it is the control, you must first rule out simple things.
1) Make sure you have power in the wall outlet by plugging in a lamp, etc. into the same outlet the treadmill is plugged into to test. Plug it in the exact same receptacle. Sometimes in an outlet one receptacle will work and the other won't.
2) Make sure any breakers are fuses that may have tripped or blown have been reset or replaced. Your local Radio Shack can help you test the fuses. Use the same type of fuse. Changing the value of the fuse can be dangerous or cause a fire.
3) Make sure the power switch is turned on and the safety key is inserted into the console if you have a safety key.
4) Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
5) Test for a motor control failure. Typically if you have a failure, the treadmill will continue to turn on and operate normally until you try to input speed. If the treadmill operates on what we call a closed-loop system, it will give you some type of error message. If it operates on an open-loop system, the computer will run normally but the motor will not turn.
6) If you have a multimeter, you can test to make sure you have DC output from the controller spades. First make sure you have 120 VAC going in to the controller. On most controls, you can use a linear taper potentiometer or jump the W and H circuits of the control with an insulated wire or insulated pliers and apply AC voltage. The DC output spades should output DC voltage if the control is good.
7) The motor can be tested by using a simple DC cordless drill or lantern battery. MAKE SURE TO USE A DC POWER SOURCE…DO NOT USE AN AC POWER SOURCE OR YOU CAN RUIN THE MOTOR. We use an outside DC power supply in our shop or field. See our test topic on motor testing for info on how to test a DC motor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 01, 2010
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
X3 goes faster that set speed on incline
Run the software calibration for easy diagnostic and fix it.
God bless you
Jul 09, 2013 | Exercise & Fitness
Motor runs all the time
test the speed sensor, with DVOM, for open or faulty. clean it, adjust it see the diagram , and tigh very well the connector. RUN the software calibration for troubleshooting, and fix it. God bless you
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 27, 2013 | Proform 730 Folding Treadmill Model...
Nordic Track T5.3 is does not run only inclines to the highest level and back down, what could be the problem?
please RUN the software calibration and fix it
.God bless you
Mar 13, 2013 | Nordic Track Exercise & Fitness
X9i incline trainer clicking
Step 1:
RUN the calibration software . and fix it. God bless you
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 2:
Feb 07, 2013 | Nordic Track Incline Trainer X9i...
Tempo 621T treadmill incline Incline reads 0.0 but is not all the way down. How to bring it down.
you must RUN the software calibration, for troubleshooting and fix it.
See the steps.
The Steps fhor Newer Style Console Calibration:
    1. F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
Reebok i run
RUN the software calibration for troubleshooting and fix it.
God bless you
follow the steps.
he Steps for Newer Style Console Calibration:
Jan 08, 2013 | Reebok treadmill i-run pure
Westo cadence treadmill speed on led display wrong
Step 1:
Run the software calibration for easy diagnose, troubleshooting, and fix it. God bless you
The Steps for Newer Style Console Calibration:
Step 2:
try to Adjust THE REED switch, test for open or faulty, clean it, and tight the connector very well, see the diagram attached.
2) Replace the batteries by new ones, with hybrid rayovac, with the same polarity, clean the contacts batteries.
Jan 07, 2013 | Exercise & Fitness
Treadmill wont speed up
RUN the software calibration for diagnose, and fix it.
God bless you
Jan 06, 2013 | Exercise & Fitness
Exercise & Fitness Logo
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Jim Dowell
Techmotionusa.com
Techmotionusa.com
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
