Question about Maytag Refrigerators
Refrigerator warm but freezer still working good
  • Maytag Master
  • 4,655 Answers
Could you possibly tell me if your freezer is frosting over on the rear wall and the model number. Some models have auto dampers between the freezer and fresh food compartment and it could be a defrost problem. Maytag made so many different variations of your model I will need to know which one to give a good answer, Some models had dual evaporators one in freezer and the other in the fresh food compartment. But I will tell you what is going on if you write me back. Maytag numbers look like this MSD2660KG for example, I will look for your response soon. Sea Breeze
Posted on Feb 01, 2010
Freezer is working, refrigerator is warm
You probably have a defrost issue with the freezer. Cold air is passed to the refrigerator section from the freezer, when the freezer does not defrost air flow to the refrigerator is eliminated causing the refrigerator to warm up. Check for icing on the back wall of the freezer. If no ice on back of freezer, check the damper assembly going to the refrigerator section.
May 26, 2015 | Refrigerators
Roper refrigerator warms and freezes
More than likely, you have a failed component in the defrost system. Call a good, reputable, service company. You do not need to replace this refrigerator.
Oct 01, 2014 | Whirlpool Refrigerators
FREEZER WARM AND ICE MAKER DOES NOT WORK
ice maker will not work if freezer is not at the right temperature. Refrigeration problem or refrigeration control problem. Might need to seed refrigeration technician. good luck.
Jun 25, 2014 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator starts off cooling after a while starts blowing warm air cleaned off condensor coils very good. cooled for a day and back to warming up what could be the problem?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 05, 2010 | Frigidaire FRT21H8 Top Freezer...
Refrigerator is warm, but freezer works. Coils are frozen.
you are having a defrost problem, probably needs if it is a maytag, it probably needs a control.
Jun 15, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Frig warm, Freezer Cold
I have experienced this with other refrigerator freezers. The most likely cause is that the warming element in your automatic defrost system is no longer working. Ice is building up on the cooling coils and this prevents the refrigerator from getting cold. I have always called an appliance repairman to fix (~$150). If you're handy you can try yourself, but you still have to buy the part at retail. Good Luck
May 03, 2009 | Refrigerators
Freezer doesn't freeze or make ice cubes, refrigerator warm
1. check the temperature is sat to. 2. Bring it up a little bit. if that does not work it must be runing out of gas, and tht can usually be refilled by someone that works on refrigeration or Air Condition, because of the equipment needed....Good luck!!!
Apr 08, 2009 | Refrigerators
WHIRLPOOL side by side freezer works fine but frig warm
You may think the freezer is fine, but stick a thermometer in to be sure. It should be around 0 degrees F. If not, you may have iced up coils. See some other posts on this site about getting to those coils and defrosting.
Jan 20, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
120 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
