Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
F-2 keeps coming up and the oven shuts off - Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
  • 6,784 Answers
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Feb 01, 2010
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 | Ovens
Model 790.47912600 keeps shutting off . It doesn't trip the breaker ,just cuts off and will come back on
Check the main board for a bad solder joint at one of the relays. Repair or replace as needed.
Jun 09, 2014 | Kenmore Ovens
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
I'm a landlord and my tenant's oven will not heat up to the proper temperature intermittently. I had a guy come out and test the oven and it works fine, yet my tenant is still complaining the oven is not...
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
Mar 13, 2010 | Ovens
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
62 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
