Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Duet Dryer smells like burnt popcorn when runing what could the problem be
4 Suggested Answers
  • 736 Answers
SOURCE: The inside of my Kenmore Series 70 gas dryer
you might have lint drawn into the air intake of the burner .. or air flow could be restricted by a clogged outlet tube .. in both cases you have to get inside the machine and clean it properly .. that should be done every couple of years anyhow .. the passagways inside the machne must be cleaned as well as the 3 or 4 inch hose that goes to the outside .. also make sure the flapper valve on the outside exhaust is free and not clogged by animals, grass or lint ..
Posted on Nov 12, 2009
Testimonial: "I was planning to checkout the lint vent hose next, but the tip to clean inside the machine is helpful."
  • 17 Answers
SOURCE: dryer must have ignited lint inside the cabinet " smells like burnt popcorn" now the dryer takes forever to dry the clothes.
check your venting !!! run a load with out the vent pipe on the back see if it drys normal if so your problem is in you vent duct to the outside
Posted on Dec 10, 2007
  • 14 Answers
SOURCE: my Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Posted on Apr 06, 2009
How to gt rid of burnt smell inside the microwave from burnt popcorn
Wash with baking soda wipe out clean then wipe down with vinegar
it will eventually go away.
May 17, 2014 | Microwave Ovens
Ge duet dryer smells and is rattling
what is your model number is then we can get started then
Sep 09, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
I was women up to a strong smell of burnt popcorn in my room. It's no where else in the house except for the room. My room is also where the breaker box is. Could this be an electrical problem?
Short answer - yes. While a "burnt popcorn smell" is not typical of the smell of an electrical problem, it is possible. You may also hear buzzing or crackling sounds coming from the panel, too. This is an indication of a loose, overheating connection that should be checked out sooner rather than later.
The fact that you were awakened by the smell, suggests that it was night time and likely that most of the other people in the house were also sleeping. The major electric appliances in the hose were probably off because of this - except for maybe the electric water heater, washer or dryer (they work just fine unattended), and sleeping people do not make or eat pop corn.
Feb 04, 2012 | Hammering
Everything is working on the Dryer but it has a very strong. "Burnt" smell inside and it gets on the laundry. What is causing it to have that Burnt smell?
burnt smell like rubber or like lint burning whens the last time you delinted your dryer? A dryer should actually be delinted at least once a year maximum I personally delint mine every 4 months with a family of 4 lint doesn't just go on you lint screen and away it goes unscrew that bottom panel and with a flashlight have a look inside on the other hand if it is a burnt wire smell you probably want to look near the through the same spot but on the left side back where the heater is located usually one of the wires connecting to the heater ends up singeing or a thermistor blows out you will get this smell if you happen to have the model number i could send you a schematic of how it comes apart if you have any further questions message me back and please remember when our chat has concluded to rank how this opinion has helped it how im able to help others in similar situations in the future Thanks again Rick
Jan 21, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Clothes smell burnt
THERE SHOULD BE TWO SCREWS ON TOP OF THE PANEL UNDER THE DOOR ONCE YOU REMOVE THESE THE PANEL SOULD COME OFF
Sep 21, 2009 | Whirlpool GEW9200L Electric Dryer
Need to clean air filter of burned popcorn smell
You would be better off to replace the filter. Purchase two and use the first one to capture the remaining smoke residue. Then install the other clean one to keep microwave free of smell. Check the web site www.partselect.com for the replacement filter. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Microwave Ovens
My Whirlpool duet dryer is getting too hot
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
Dryer must have ignited lint inside the cabinet " smells like burnt popcorn" now the dryer takes forever to dry the clothes.
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Burnt smell in dryer
Open the service panel and check that the heating element is clear from any lint on it. Be awre you should unplug the power cable before touching the heating element. Good luck!
Sep 01, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
629 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
