Question about IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 won't turn on
When i press the power button it just blink and theirs nothing on the screen
  • 4 more comments
  • heny Mar 04, 2008
    I was able to get it boot up for a few weeks by bending it a bit on two opposit cornrs, but in a sudden stopped and it is not turning on again. When I press the power botton the green light just blinks and that is all. I am tempted to replace the Motherboard. Any suggestions?
  • Anonymous Apr 08, 2008
    I have a black screen green light is on no fan sound at all
  • Anonymous Apr 30, 2008
    balck
  • cookie1993 Feb 28, 2009
    the light just blinks when i hit the power button
  • Anonymous Mar 18, 2009
    i have the same problem. i have remove the battery and AC adapter for couple days or week. then it will works again. but couple weeks later, same happen again. please help.
  • mile Apr 09, 2012
    instructions for opening the laptophttp://www.youtube.com/watch?v=4dQlLn1Gw...
    Remove the hard disk, battery life, then everything neatly back into place.
    I solved the problem "when I try to turn on the laptop, the pilot light just flashes"
    Problem Solver:
  • 5 Answers
You have what is known as the Blink Of Death (BOD). There are several things that seem to work, but none of them ALWAYS work.
What works most of the time for most users seems to be the following. Remove the main battery. Remove the AC adapter / charger. Press and hold the power button for at least ten seconds. While holding the power button down, plug the AC adapter / charger into the unit. If you are using a Ni-CAd or LI-ON battery, you should NOT leave the battery in the computer all of the time the AC adapter / charger is connected to the unit. NI-CAD's develop a memory of sorts with repeated short re-charge cycles. LI-ON batteries a limited number od re-charge cycles and they have microprocessors inside the battery housing that are there to attempt to evenly control the charge to the individual cells. Google Blink Of Death for more information.
Good Luck,
Merlin
Posted on Mar 27, 2008
  • mile Apr 09, 2012
    This is the best answer, I solved the problem
  • Francisco Feb 27, 2013
    Solved the problem. Thanks
I just took the battery out and pluged in the ac & it started up no problem. Hope this works for you.
Tim
Posted on May 17, 2009
Well,I left my computer sitting without the battery for about 1 week inserted it and it worked well for about 1 hour so i had enough time to save important information,i hope this helps if you have info you need to access important things.
Posted on Jun 23, 2012
    Scholar:
  • 101 Answers
Try removing both main and backup battery (under main battery, remove 1 screw then gently remove - made need to lift out a bit w/small screwdriver or paperclip) then let sit with no power 24 - 48 hours. Then leaving batteries out plug in to AC and try to start - you should get the BIOS error that time is set wrong go ahead and set this and finish booting and if everything works, DO NOT SHUT OFF but back up critical data. Then turn off and see if it will restart. If it won't it is probably a bad capacitor and leaving the batteries out allows the cap. to fully discharge. I am searching for more info but haven't found a sol. yet so you either pull the batteries and wait 2 days or leave the laptop on - screen open but you can let the screen turn off just don't let it hibernate or go to standby.
Posted on Feb 21, 2008
I had the same issue... still trying to resolve it... followed your instructions to the word,,, but still no luck... anything else i can try?
Posted on Feb 20, 2008
    Sergeant:
  • 324 Answers
1. Reseat the memory chip(s), and try again.
If that doesn't work:
2. Remove the battery, Hard Disk drive, wireless card, any PCMCIA cards, floppy drive, CD drive and all but one memory chip. Try again, and see if it comes up any farther.
Swap to the other memory chip (if you have a second.one)
At any point, if it comes up to further than it did, start replacing one item at a time. This should help you find the bad part.
If none of this works, get back to me for more ideas.
Ron-
Posted on Feb 18, 2008
T22 disk read error
Sounds like the Operating System is corrupt. I would re-format the hard drive and re-install the OS that should solve the problem. If not then the Hard drive needs to be replaced.
Jan 23, 2012 | IBM ThinkPad T22 2647 Notebook
I was given ThinkPad 2647 T22 and it has been in it's case for 1 year. I plugged it into the AC adaptor and the green indicator light came on that the battery was charged after 5 hours. When I pushed the...
Remove the battery and try to power on without it. Replace the battery if the computer powers on. If not, the motherboard have to be repaired/replaced.
Aug 15, 2010 | IBM ThinkPad T22 2647 Notebook
Screen is not working
Assuming there is nothing wrong with your power connections, which you should check first -- remove battery and unplug unit, disconnect peripherals. Then hold in the power button for at least 60 seconds, reconnect to power source and see if it has reset. No guarnatees but it may reset if it was shutdown due to power surge.
Apr 25, 2010 | IBM ThinkPad T22 2647 Notebook
I power the device on and get the 'IBM ThinkPad' logo screen. Nothing happens after that
Since you are getting the IBM Thinkpad Logo it is confirmed that you have no hardware error. All you need to do is restore the operating system. most of the IBM laptop has an inbuilt recovery option. just press the access IBM/ Thinkvantage (blue button) immediately after pressing the power button and follow the screen..
hope this helps.
Apr 06, 2010 | IBM ThinkPad A22p 2629 Notebook
Can't power up. my IBM ThinkPad T22. I have the green light that indicates that it's charged up, however when I push the power button it just makes a flash and nothing happens.
If you only get a green light, try removing the battery first. If a laptop battery has gone bad, it will prevent a laptop from booting up.
Now, if removing the battery doesn't resolve your problem, check the laptop charger to make sure that the adapter has not malfunctioned.
If your fans are spinning, then the problem is probably the one listed below.
The transformer may not be converting the voltages properly.
Try these steps first. If it comes down to the internal transformer, then you have to contact IBM.
Aug 09, 2009 | IBM ThinkPad T22 2647 Notebook
Can barley see screen on t22 thinkpad
It might be that the power supply, battery, or backlight. Try pulling the battery out using just the power supply. If you have another power supply try that also.
Jun 25, 2009 | IBM ThinkPad T22 2647 Notebook
Rebooting
That's the answer, I think, hold down the power button firmly until the laptop shuts off, then release and press again to turn on. Some desktops are like this, they have no reset button.
Feb 13, 2009 | IBM ThinkPad T22 2647 Notebook
STUCK ON STANDBY MODE
Ok, I want this off my screen. If it is stuck in standby mode as you say, press and hold the power button until the computer goes "dead." Then turn it back on. If this doesn't work, unplug it and take the battery out for a while.
Nov 22, 2008 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 2647 Notebook Logo
2,293 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
