Question about Kitchen Ranges
What does f-2 mean on a whirlpool range - Kitchen Ranges
  • 725 Answers
Depending on your model, this could be your temperature sensor. To be sure of this diagnosis, I suggest you get your model number and contact us to make sure this is the problem. You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7AM until 7PM CST for the answers to all your appliance repair issues.
We will happy to help you diagnose as well as provide PARTS to you for your issues.
We look forward to working with you! Thanks, Ella
Posted on Feb 03, 2010
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
The Oven and Range are working; however I have a F5 code on the display. Can you tell me what this means?
The F5 code means that the range door isn't latching properly (for some Whirlpool ranges). Check the latch when the oven is cool. If it is loose, tighten the screws that hold the latch. Try opening and closing the door to see if the latch is clicking shut properly. Then unplug the range for 30 seconds to a minute to reset the unit. If the error clears, you're done.
If the error persists, clean the latch area. With the oven not in use, rub the latch area with a cloth that you dunked in hot water and wrung out the excess water. Then dry with a paper towel.
If cleaning doesn't help, the latch probably needs to be replaced.
I hope this helps. Please give me the model number of your range for additional ideas. Whirlpool has the user's manuals for most of their appliances at their site. See http://www.whirlpool.com/custserv/index.jsp and the Manuals and Literature search box.
Jun 06, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool ranges error codes e1 what-it means
E1 means a problem with your door lock. The solenoid is not operating or your latch switch has failed. You will need to inspect this assembly to see where the problem lies. Use this link to see some detailed instructions.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203196077.pdf
Jan 08, 2010 | Whirlpool GR460 Electric Kitchen Range
F2 code on my whirlpool stove buttons not working.
The F2 could mean a timer/control has detected a stuck/shorted keypad. Depending on the model number though it could also mean a shorted oven temperature sensor.
In the event it is a stuck keypad detected, the timer or keypad will need to be replaced. You should first attempt to reset the breaker or unplug the range for a couple of minutes to see if that resolves the error code.
If it is the model that uses F2 as the shorted sensor code, you`ll need to replace the oven sensor, there`s no way around that one.
If you can provide a model number by replying to this post I could try and be more specific, as right now I can only generalize with the most common F2 error codes meaning for Whirlpool manufactured ranges/ovens.
Hope that help`s, let me know.
Good luck.
macmarkus :)
Dec 06, 2009 | Whirlpool 30" Freestanding Gas Range -...
I have a Whirlpool Super Capacity 465 range and received the error messages E4 F3. What does this mean?
if you call me @ 570 263 0077 i will check my fault code list and let you know what those codes meam thanks JOHN
Nov 08, 2009 | Whirlpool GR460 Electric Kitchen Range
What does E4 - F3 - mean on display on range
It means something may be wrong with the oven sensor. The Whirlpool technical manual says:
Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor.
If you need help on how to do that, let me know.
Aug 23, 2009 | Whirlpool Gold GW399LXU Gas Range
Whirlpool gas range SF387PEY code F1 cause
call me @570 263 0077 and i will go to my truck and get a fault code li st and tell you but i think it means replace EOC
Aug 05, 2009 | Whirlpool GR460 Electric Kitchen Range
GR448LXPS electric whirlpool range got the error code E1 F1
This Is what the E1-F1 means and what you need to do to fix.
Safety flip flop Replace Electronic Range Control/Clock (ERC)
Feb 25, 2009 | Whirlpool GR448LXPQ Electric Kitchen Range
Whirlpool Gas Oven
The F1, E2 codes mean you have UL ac-dc errors. This means you need to replace the control.
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
115 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
