Question about Paxar Monarch 9403 Thermal Printer
Check Prinhead problem
Monarch 9403 tag Printer shows message "check printhead" when you press continue the printer is fine, prints great no other issues until we power it off. It repeats the error each time we power it up. Printhead is fine.
  • 113 Answers
This one is somewhat tough.
Most times when you get this error, you actually do have a printhead issue and you need to send the printer into their service department. If you're not printing a barcode, then these printers may show you this error, allow you to continue printing, but will print a grey box instead of barcode if there are bad dots falling within the barcode itself.
If the latter is your issue, sent it in. If the latter isn't your issue, you could potentially plug along without any worry until the human readable starts to get unreadable. Again, that would be the time to send it in.
Posted on Sep 28, 2009
  • 155 Answers
This error occurs when the head has some damage. Check also that the head of the cable is properly connected.
Posted on Mar 10, 2009
I get A fault code of 616. Cleaned print head. 618-744-9830 ext 281
616 is a dot shift error on the printhead. You need a new printhead.
Jan 27, 2011 | Paxar Monarch 9403 Thermal Printer
The Monarch 9403 does not print out multiples of labels continuously, it stops between each single label. Can you help? Cheers Debbie
I may need a little more information.
If you are using a 3rd part software application like that from Loftware, you may need to create your labels in such a manner that the print module prints strips of labels, and in the quantity that you need. Then the printer should produce the quantity each time you go to print.
If you are using a 3rd party driver, like that from Seagull Scientific, then you need to tell it to print that quantity, just like you would when printing something on your inkjet printer.
If you are sending the printer's native language directly to the printer, there is something called the format header. It looks something like this:
The second 1, is the quantity of labels. So if you want it to print 5, you need to change it to something like...
If neither of these make sense, please provide some additional details so that I may provide further assistance.
Jun 25, 2010 | Paxar Monarch 9403 Thermal Printer
How so I remove the old prinhead and install a new one
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. Scroll to the Printhead menu icon (icon on the lower right of the front panel display) and press Enter.
  4. Scroll to Replace Printheads and press Enter.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. When instructed, open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts in all carriage slots and on all printheads (instructions below).
  10. Allow the contacts to dry.
  11. install the new printheads and close the carriage cover.
  12. Close the top cover.
  13. Turn the printer on and attempt to verify functionality.
Apr 18, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Zebra printer P430i. wait for temperature check
Try reducing your printhead intensity settings at the printer driver settings.
-- The Pros at
Aug 12, 2009 | Zebra Printer 140-751-00000
How do Iget into the gear area of my Monarch 9400 Printer
The Ink reals and printhead assembly are all mounted on the single
black plastic mold which is held down by three mounting screws.Two
of the mounting screws are up front ; one within a long thin well, the
third is in back. Any long thin Philips Screw Driver will do.
Jul 30, 2009 | Monarch 9403 Thermal Label Printer
Attempting to print labels from a Monarch 9855 printer and receiving error message: "Print Head error 768." Printer was working fine as of last Friday. We have other Monarch 9855 printers that are on other...
the problem is your printhead is bad . do a print test by presing both arrow buttons at tah esame time for two seconds, look fo rthe line that reads bad dots. if the value i sgreater than 000 yu have a bad printhead
Jun 08, 2009 | Monarch Paxar? 9855 Label Printer
9403 monarch printer/hooked to lantronix print server
If the printer doesn't react when you send a print job to it (either prints, or displays an error code on the display) and just sits there doing nothing, it generally means the print job didn't get to the printer. Check your communication settings. The printer comm settings must match the settings in your software. The default comm settings on the printer are:
Baud : 9600
word length: 8
stop bits: 1
parity: none
flow control: dtr
Apr 27, 2009 | Monarch 9403 Thermal Label Printer
#765 problem
sounds like your printhead is bad. ty running a print test by havind eaither tags or labels in the supply. then clear the machine and press and hod down BOTH arrow buttons at the same tiem and then release. a print test will apear and carefully look for the line that reads BAD DOTS ;
if the value is greater than 000 than the prinithead needs to be replaced
Sep 26, 2008 | Monarch 9855 Thermal Printer
Paxar Monarch 9403 Thermal serial to usb
The 9403 has no USB port, you must use a serial to usb adapter into the pc and select the COM port that you assign to the adapter.
Aug 07, 2008 | Paxar Monarch 9403 Thermal Printer
Paxar Monarch 9403 Thermal Printer Logo
175 people viewed this question
Top Paxar Office Equipment & Supplies Experts
Are you a Paxar Office Equipment and Supply Expert? Answer questions, earn points and help others
