Question about Epson Stylus Pro 4000-PS InkJet Printer
I manually cleaned my epson pro 4000 which worked fine before cleaning. aferwards, teh machine read 2 error messages: 00010004 and 0001001D. aftermoving the print head - i only get message 001001D now and printer head will not move. I may broken the carriage release tab by accident, owever it is in place and moves left and right as before. i checked and it is in left most position.
  • 9 more comments
  • tom Feb 01, 2010
    after some research, Epson offerred this:
    The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder.
    where is the t fence located?
  • tom Feb 01, 2010
    i have located the following diagram for the epson pro 4000:
    http://www.bytes2print.com/parts-service...
    but cannot locate the legend to this diagram -do you know ?
  • tom Feb 01, 2010
    can anyone shed light on the location of the T-fence and carrier encoder? or other solutions for the error message of 0001001D?
  • tom Feb 01, 2010
    the carriage release tab is still in place and operates according to manufacturer. that is the only piece that may have been altered; however it still performs its function and is in the correct released position (far left). Can anyone else help with this?
  • tom Feb 01, 2010
    I found that information on my own before joining FixYa. So far, the "experts" have not helped me at all!
  • tom Feb 02, 2010
    thank you for your intelligent reply!
    how do i locate these parts on the machine? I have a diagram, however, do not have the legend, (I found it online)
  • tom Feb 02, 2010
    the field guide mentions that if the cap and pump assembly are not properly seated, it will give carriage errors. when i performed manual cleaning i removed the flushing box, cleaned it and replaced it. i did nothing else; except had a hard time figuring out how to move the print head to the left. It seems to move to the left easily without depressing the cutter blade. left in the left position, it moves to the right side easily when turned on, continues further to the right, i hear a sliight thump and the error message comes on.
  • tom Feb 04, 2010
    This last solution is the closest to being helpful, however, I read that if the cap assembly or flushing tank is not properly seated, it can give carriage movement errors. That is what I did - take out the flushing unit and replace after cleaning, then the error message...
  • tom Feb 07, 2010
    I am looking for a service repair place or engineer for this problem in the Brooklyn area,of zipcode 11205. Does someone know a reliable tech or repair center that could handle this issue other than the center Epson recommended who wants to charge me $225.00/hr just to look at it? and then $225.00/hour + parts.
  • tom Feb 14, 2010
    Thank you for this information. Yes, I believe the encoder alignment is off and I will try this repair today. Thanks again for this detailed information, it was worth joining the site for your response and one or two others here. Thanks also for your advice regarding the manual, however the
    Servicemanual site is a rip-off! They charge about $25 - 30 for a manual that I was able to find online for free. Most manuals are down-loadable by manufacturer online for FREE! Please advise others of this as well and do not send them to that site which will charge them for free information!
    Thanks again.
  • tom Feb 14, 2010
    Excellent suggestions and directions surpassing 6 other experts! Only thing that is not a good idea is your advice about theservicemanualshop. They charge for manuals that can be downloaded for FREE on most manufacturers' sites. Thank you! Tom
  • 313 Answers
001001D is a servo parameter error.
Most likely it's because you moved the carriage off the capping station and a sensor is sensing the error.
If the print head is still on the left, turn the printer off and back on. If the print head is in its normal docking position, move it to the left and turn printer off and back on.
Things you should Check:
  1. Check the basics first:Is the encoder attached and correctly routed through the optical sensor
  2. Is the encoder strip clean - if there is a splodge on it, this will result in error
  3. If you have done maintenance, check all the connections you made are good
00010004 Motor encoder check error
00010004 error relates to the encoder strip for the carriage motor (The encoder strip is like a piece of graph paper and the head has an eye that reads how many lines it passes). This is so the machine know exactly where the head is at any point
The error means that the machine is not correctly reading the encoder impulses. The encoder, eye or the circuit board may be broken even the cable could be faulty. It could be that you have done maintenance that one of the connectors has been replaced with incorrect polarity.
There is no one answer I can give you. If you need further help with this, there a good section in the service manual that gives a sequence of areas to test to pin down the fault. Get a manual from http://www.TheServiceManualShop.com
I hope this gets you going and thank you for the chance to help.
If you have any other questions, please feel free to to ask.
Randy
FixYa Support Team.
Posted on Feb 09, 2010
  • 265 Answers
Make sure the carriage locking tab is pulled all the way out. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause any of the carriage errors.
FYI:
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
Posted on Feb 03, 2010
    Guru:
  • 458 Answers
This seems to be more of a hardware problem than a software issue.
The error messages might be resulting from lack of hardware functionality.
You might have accidentally damaged a hardware component during the cleaning process.
Unfortunately, when it comes to printer hardware, it is almost impossible to tell where the exact problem is, unless the printer is physically looked at.
To get this problem better looked at, and have it solved, you will have to take it to a service center, where the problem will be detected, and fixed.
Thank you for using Fixya,
Kenneth.
Posted on Feb 07, 2010
  • Kenneth Obua
    Kenneth Obua Feb 07, 2010
    Have you tried a local computer repair shop?
    I dont think you have to take it to a very expensive place.
    If you can find a local computer repair shop, they will fix it for you at a much cheaper cost.
    Thank you,
    Kenneth
  • Kenneth Obua
    What they are charging you could cost more than the printer itself.
    Unfortunately i live in Africa and dont know any local repair centers in Brooklyn, but i am sure if you look around you will find a much cheaper place.
    If you can take it where you bought the printer from, they might be having a repair service there, they could help you.
    You do not have to take it to a place Epson recommended, this problem can be solved by a skilled technical expert at a local service center.
    Thank you,
    Kenneth
  • 526 Answers
The 0001001d means CR servo parameter error.
Check the CD encoder sensor and the CD scale must free of dust.
check the CD timing belt must have no defects and proper tension
the carriage unit must move freely
all the harness must be connected properly
perform the cr timing belt tension adjustment
if these dont work,
then replace in the following order.
1. encoder sensor
2. cr motor
3. main board.
I hope this helps
Posted on Feb 02, 2010
  • 341 Answers
Q: Why am I seeing the message Service Request 00010004 - 000101D? A:
  • ServiceRequest errors in the range 00010004 - 000101D are related to acarriage movement problem. In some instances like paper jams, thecarriage locking tab may be partially pushed in, causing the carriagelocking mechanism to put a drag on the carriage or lock the carriagecompletely. This will cause any of the carriage errors. Make sure thecarriage locking tab is pulled all the way out. Then turn the printer'spower off and release the carriage by pushing down on the cutter blade.Slide the carriage to the left and look for any paper that also may berestricting the carriage from moving freely.
  • 00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
  • TheT-Fence can also be dirty or out of the carriage encoder. Check to makesure it is clean and in the center of the encoder. Contact Epson foradditional assistance.
  • The current firmware corrects erroneous Service Request 00010007, which occurs after the power is first turned on. You can download this firmware upgrade from www.prographics.epson.com.
Posted on Feb 01, 2010
  • 4,472 Answers
If you knowingly broke something while cleaning it, then most likely the damage you did to the unit is causing the errors. It is best to follow the instructions provided by the manufacturer and always use care when dealing with any internal parts of a printer. You may want to consider repair or replacement.
Thank you,
Lee
  • 542 Answers
This is error you are gettiing is due to carriage is not freely moving or struck in between. Need to repair/replace the same with the help from expert engineer or service center experts.
Revert back for more assistance.
Maintenance request error code 4000 for Epson stylist pro 4900
HI,
MAINTENANCE REQ - 4000 - It detects twice in a row that all the nozzles are clogging.
Check the video to know how to clean the nozzle to get ride of error 4000
How to clear nozzle clog on your Epson wide format printer from PRO...
www.electro-medical.blogspot.com
Mar 04, 2013 | Epson Office Equipment & Supplies
Epson 4000 will not see new ink cartridges
epson is crappy printers i know alot of people like it on repairing them i will never buy epson or brother ... anyways hopefully you have OEM/REAL epson cartridges.......otherwise it will give you an none or empty cartidges.
Jun 29, 2012 | Epson Stylus Pro 4000 InkJet Printer
Epson stylus pro 4000 i have a clogged nozzle cant move it other 7 are fine
Inkjet printers needto be used frequently to prevent ink drying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 03, 2011 | Epson Stylus Pro 4000 InkJet Printer
Epson Stylus Pro 4000 got the 0001001B error, I tried to restart the machine, but the error still comes up.
When determining a solution for an error, always look to what changes you instituted just prior to the error. In my case, I switched from FW to USB. That brought on the 0001001b head driver (tg) temperature error. When I switched back to FW, the error went away and the SP4000 display reads "Ready"
Apr 19, 2010 | Epson Stylus Pro 4000 InkJet Printer
Cartridge problems Epson 4000
Where are you located? is it Humid? possibly the chips on the cartriges have something on them (corrosinon, oil from a finger touching the chip, etc) that is interferring with good contact with the wire "feelers" inside the machine. clean the chip with Qtip and alcohol, or fine fiberglasss bristle battery contaact cleaner (hard to find these days)
May 13, 2009 | Epson Stylus Pro 4000 InkJet Printer
Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Hope that the manual contains everything you need from nozzle check to sensor errors.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
I have an Epson 4000 which has a clogged nozzle
I have an Epson 4000 which I started using new in Sept 2004 and my magenta is clogged too. I've gone through 2 maintenance tanks trying to clear it, (and LOTS of ink), but the magenta is still blocked. I even tried this: http://www.youtube.com/watch?v=3NR8g4qUAJc trick but it didn't seem to work. I hope you have better luck.
Feb 23, 2009 | Epson Stylus Pro 4000-PS InkJet Printer
Epson Stylus Pro 4000-PS InkJet Printer Logo
1,352 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
