Question about GE Refrigerators
Clicking noises and ice maker not dispensing - GE Refrigerators
Mine done the same -motor on front of icemaker is broken. call at your service today
Posted on Feb 01, 2010
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Ice dispenser solenoid continually clicks
If the ice maker is working ok and you can live with the noise leave it alone. Eventually the solenoid will fail.
Don't worry though it's an easy fix. You'll need to replace both the ice maker and the water dispenser solenoids. They're located behind the hardboard cover on the lower right side (looking at the back of the refrigerator), where the water comes in.
Parts are under $50 and the job should easily take less than 1 hour.
Feb 04, 2014 | Electrolux Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
My ice maker fails to make ice, and seems to get "stuck" between batches, causing a clicking noise that occurs continuously about every 30 seconds. Any suggestions?
check for a stuck ice cube, something is preventing your ice maker to advance, if there is no ice cube, replace ice maker part #wr30x10093 for standard in freezer ice maker or part #wr30x10097 for ice maker in refrigerator
Aug 26, 2010 | GE Profile Performance 23.5 cu. ft....
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Dispenser not responding
On mzd2766 there is a solonoid type switch that goes bad. Could be your problem too.
Aug 16, 2007 | Maytag MSD2754G Side by Side Refrigerator
Clicking noise
THE FRONT PANEL IS DEFECTIVE. HAVE REPLACED TWO IN LAST MONTH. JUST TAKE NOTE OF MODEL WITH DEALER AS CERTAIN MODELS HAVE TO HAVE THE POWER BOARD REPLACED AS WELL.
Jul 07, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
