Question about Yamaha DSP-A1000 5-Channel Amplifier
Distorted sound Hi Folks, Distorted sound at all levels including headphone socket. Can you help?. Brian Dinsley New Romney UK. Sony stereo amp TA-F448E
  • Briax Feb 22, 2008
    Thanks,
    speakers ok but distorted R/H channel only.
    Briax
  • Briax Mar 04, 2008
    Thanks Jango2,
    I've done what you  suggested ( very useful picture of layout too)
    but there are no ceramic resistors to the right of the transformer, which should be pretty obvious. Unable to fault find any further
    but thanks a lot for trying.
    Briax
    Novelist:
  • 236 Answers
Have you tried switching source channels? right to left v.v.
red
Posted on Mar 18, 2008
  • Redentor Rivera Mar 18, 2008
    sorry briax, i thought i was on another brand. your DSP a1000, i will narrow your problem to 2 parts only. Your input selector siwtch which is very common troouble or the IC chip that is also controlling the input to tone control signals.
    TAF448E ?? OR IS DSP-A1000
    If it's Yamaha, get the input selector swith replaced, that should be it. Yamaha out protection is very sensitive and slight deviation in your normal output current it will trip. Yours is distorted so it must be the signal only, common trouble for mechanical switch DSP A-1000
  • 38 Answers
Are you a technician capable of internal repair? This seems like a case of either positive or negative supply rail to right channel blown. Probably an open fuse or open series supply line resistor.
Internal view of amp here;
http://www.tarad.com/_tarad/_modules/view_image.php?picname=p6033619n3.jpg
The round orange doughnut shaped device at the left is the unit's toroidal transformer. To the right of it are these 2 legged upright, white rectangular ceramic resistors. They are typically low value with a power of approximately 5 watts. A quick cold test with an ohm meter might reveal one of them to be open.
Switch off and unplug unit before opening. Be wary of charge retained in the big fat electrolytic capacitors in the centre.
I do not suspect a case of blown output transistors since the relay does not go into protect and sound is audible but distortyed in one channel.
Safe !
Jango
Posted on Mar 03, 2008
  • 44 Answers
This is an automatic high end amp. Make sure you are using 8 ohm speakers. If the connections are correct, also use good quality speaker wire.
If this makes no difference, it seems that it would need to go to the repair shop.
Posted on Feb 21, 2008
Will a ipod player play in my sony TA-AX301 AMPLIFIER-No sound
You need a 3.5mm to stereo phono/RCA cable
Plug the red and white ends in to any of the following sockets that are free - Tuner, Tape In, CD, Aux, Video In. They all do the same job. The names are just suggestions, they're not mandatory.
Plug the headphone jack plug in to the MP3 player's headphone socket. Turn the volume up on the MP3 player to about half way. Then select the source input on the amp that matches where you plugged the cable.
That's it. Hope this helps..
Sep 16, 2014 | Audio Players & Recorders
Can i get my ipod player to play in my sony TA-AX301 AMPLIFIER-No sound
Sony ta av431 Stereo Amp Front speaker do not
Have you check your sound configuration at front panel?
Oct 09, 2013 | Audio Players & Recorders
Wires connect stereo
Assuming that your TV has a headphone socket, the easiest way is to connect a lead from the headphone socket on your TV to a spare line (or auxiliary) input on the Sony amp. You will need a 3.5mm stereo plug to twin RCA plug cable, long enough to reach both pieces of equipment. Most electrical stores should have a suitable cable available at modest cost :o)
Aug 19, 2013 | Sony TA-FE370 2-Channel Amplifier
I have a CD Stereo system SA-AK17, 120V, 145W, without speaker. I provided 2 speaker with the brand of Technics, input 200W(.music), 100W(DIN) each speaker. I bought Audio wire and connect speakers...
Some stereo system have the ability to switch off the speakers when playing via headphones. In others the headphone socket itself does the switching. However headphone sockets can become faulty and when the headphone plug is removed it doesn't restore sound to the speakers. It's very easy to fix this, with a check that the contacts are not bent out of place. Or you can rewire a new headphone socket, making a note of the wire connections before you replace it.
Sometimes it is quite difficult to get the speaker cable to make a good contact with the speaker sockets. You should check that they are making contact.
To test any loudspeaker just connect a 1.5 battery for a short time across the disconnected speaker. If working the speaker will pop!
As the sound is going to the headphones the amp seems to be OK and one of the above options should correct the problem.
Oct 27, 2017 | Panasonic SC-AK17 Shelf System
Sony preamp has no speaker output but headphone jack work fine
Hi...
If this thing is a pre-amp , it will not drive any speakers.
You'll need a power amp to connect the output of the pre-amp to...then speakers.
PLease rate my help ...Thanks
Scott
Mar 22, 2009 | Sony Audio Players & Recorders
No sound coming out the headphones
Try the line out on the back of the unit and see if sound signal comes out there U must plug that into a preamp on your stereo the signal level is to low for the headphones to sound and if there is sound then u have a blown output amp in the headphones circuit!
Dave Electronic Doctors email eledocs@hotmail.com
Feb 15, 2009 | Sony Walkman WM-D6C Personal Cassette...
Yamaha DSP-A1000 5-Channel Amplifier Logo
251 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
