Question about Proform 575 Crosstrainer Treadmill
My son was running on the treadmill and a fire ball shot out the right side of the treadmill. does this treadmill have a fuse? Or does this mean the treadmill is done for?
    Problem Solver:
  • 69 Answers
    Champion:
  • 218 Answers
The motor or controller has burnt up do the following to test the motor;
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 13, 2010
Fuse keeps blowing immediately when switching on the treadmill, why does this keep happening?
A fuse is designed to prevent excessive current from flowing into a circuit. If the latter is not protected by the fuse, the excessive current can either cause some serious damage or the excessive current can overheat parts and perhaps result in a fire.
So, you are drawing too much current and that explains the small plume of smoke you experienced. If an electric motor runs slow because of excessive friction or load, it will use too much current, overheat and burn out the windings. Disconnect the motor and attempt to run the unit with the motor disencumbered. If the new fuse does not blow, then the problem is with the drive mechanism. If fuse blows, the problem is with the electronics and not the motor.
Aug 26, 2015 | Exercise & Fitness
I have a kohler courage 26 hp pro v twin its not firing on left side swap coils around and it fires on the right fine so both coils are good checked wiring and push rod they re fine any help please
Since you know the coils are good, there is only a few possibilities. The grounding wire must be causing a short to ground. Remove the ground wire from the coil. Check your spark plugs, are you swapping these too? The gap on the coil, this is a long shot, but if it is too far away, it will not fire. Are looking at the spark form the plugs? By firing you mean running, or spark. If you mean by running, check the compression. You may have a stuck valve, usually the exhaust.
Jul 14, 2015 | Garden
I have a summit 4500. the belt is off center to the left side and I have use all the adjustment and the belt doesn't move
Good day.
The belt can go off track for a number of reasons. If you say you've used all the adjustment and the belt doesn't move. To me this could mean that the belt either doesn't rotate or it is not moving to the center (centre), or to the right. I presume you mean it doesn't return to the center. But since you have said you've used all the adjustments, that also means that you have actually removed the plastic guards off to have done the supposed adjustments needed to make the belt track back in the center. So, here is the confusing part. Depending on which plastic guards you removed to do the supposed adjustments, normally the belt tracking bolts are at the foot of the treadmill. Stand on the treadmill, looking at the Instrument panel, the foot of the treadmill is behind you. There are two hex type adjusting bolts, one on each side. Now if the belt pulls left, you don't tension the left adjusting bolt, which would stretch the belt and make the treadmill labour worse. A belt that pulls sideways now but not when it was new, shows that the treadmill belt had been neglected. Instead, try slackening the right adjusting bolt to loosen the tension of the belt. An over tightened belt makes the motor work harder, leading to overheating and cook out, plus it also stretches the belt unnecessarily. A lose belt also means it slips at the revolving rotor (motor side) each time you impact the belt with your feet as you run or jog, therefore it means that the slippage will cause the rotor or the belt to wear out. To check on the correct tightness, lift one side of the belt at the center of the platform. It should raise no more that 2 and half inches. if it is less, it is too tight, if it is more, it is too slack. Either way, it is for you to experiments because you could be a six foot five and weight a tonne or you could be a four foot two and weight like a butterfly. Each person is different. Most treadmills are adjusted for up to five foot ten and for those that are taller or bigger, there are treadmills designed for them too. As you know, there are treadmills for all walks of life, small ones, medium ones and large ones, all designed for the appropriate weight ratio in mind. You can't use a small treadmill if you're six foot two and weight 14 stones (90 kg). There are treadmills to accommodate larger people. Most belt failures are the result of... like I said above, a number of reasons. One of them is the failure to maintain a treadmill. Lift the belt and place the palm of your hand on the metal platform (where the belt glides on) and feel if it is sticky, hard to slide the palm of your hand, or feels dry. If any of thei si evident, then your treadmill od labouring and that means the result of the belt running to one side is because it has been stretched as the motor laboriously and continuously been trying to keep going. I have a Stream treadmill and every month of continuous usage, I lubricate the underside of the belt with a quality silicone lubricant, in spray form. I never spray it directly underside, especially if I have carpeted floor, but if you have lino or polished floorboards, I suggest you don't spray it at all because it stains carpets and makes lino and floorboards slippery. Instead, use a lint free cloth. Go outside, spray the lubricant on the cloth to just soak one side, then shape the cloth into a ball, return inside and lift the belt at the center and apply the wet site of the cloth on the platform, not under the belt. Spread the lubricant evenly across the center of the platform but not towards the rollers, just the center. Then run the treadmill a little. Stop it and reapply it again. Repeat the process a third time, then run it again. Then stop it and lift the belt. With the palm of your hand, see if you can feel any moisture or a slippery feel on the platform. If it feels slippery, then the belt is lubricated properly. Do this only every month of daily use. The lubricating of the platform is almost very little. never over lubricate or you'll soon see that excess lubrication stains the machine. You can hear it when the belt runs dry. A belt that is adjusted and lubricated properly runs almost silent, but a dried out belt sounds raspy.
Oct 07, 2014 | Nordic Track NordicTrack Treadmill, A2550
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
1987 toyota 4runner blowing #8 ignition fuse.
behind the 8 ball........?????
How to find reason?
22R-E and 22R-TE engines? or ?
it means there is a short, and the fuse saved the for sure fire.
is fuse 8 in the dash box.?
what is the output side fuse 8 wire color.?
how many amps.?
why is fuse #8 un-named?
Feb 16, 2014 | Toyota Cars & Trucks
Hi There, My treadmill is a BH pro fitness Explorer G636. Recently the rubber from the front cilinder started to break apart. What does this means!? Too much lubrification, belt too tigth or is it the age...
Actually it means you have been a avid user of your unit.
Unplug the unit remove the motor shroud, then go to the end of your unit I believe it uses an allen wrench loosen the belt. Now while at this portion count how many times you have turn the bols son each side then write it down so when you are ready to apply the same tension you be in the ball park. Now what you need to do is actually see if it is the front unraveling or it is the running belt. then that said done call BH and order the part or parts needed complete the repair or ask them if they have a reliable servicer in the area to complete the repair for you.
May 06, 2010 | Endurance TF3i Folding Treadmill
I have a 1992 Proform CrossWalk Dual Motion Cross Trainer. Motor still works great. There is rubber covering the roller under the moving piece. It has come off on the right side. Can this be replaced?
Really, I have had my crosswalk for over 20 years. I can't complain. I am passing it on to my son and getting a NEW Proform treadmill. Their longevity has sold me.....
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
How do I adjust the tracking epic t 40 treadmills
there are screws on the back, use an allen wrench, one quarter turn at a time. To move it right, tighten the left, to move it left, tighten the right.
Sep 19, 2009 | Epic T 40 Treadmill
Low Beam headlight and front parking lights do not work
see for the head lamp relay fuse a few manufacturer install a typical fuses for seprately for relay so see weather the fuse are ok or not then see for wiring as far you mention that the wiring of right side went streached to the lower ball joint there is a possibality that wire's can break internally & may get shot circuited due to cross circuit & may cause this sort's of problem & if possible show it to highly experience person techanican, mechanic or an authorised dealer or service centre who can sortout you car problem untill then see you soon my friend
May 08, 2009 | 1999 Lincoln Town Car
KLX 250 won't fire - new battery
-check the fuse right hand side below the fuel tank and seat, see if it is blown.
- Check to see if plug has spark, replace if necessary .
- Did you run the bike with a low battery before replacing it? could be that your stator is shot.
-Is bike trying to start but won't?
Mar 21, 2009 | 2007 kawasaki KLX 250
Proform 575 Crosstrainer Treadmill Logo
255 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
