Question about Canon PowerShot S51S Digital Camera
Erased pictures. I was messing around with my camera and I switched it from continuous to auto erase in file number and it erased all of my pictures even my protected ones. I switched it back but they still were not there. They were completely gone. Is there any way to get them back?
  • 583 Answers
You can try connecting the memory card to a PC via a memory card reader and using an undelete utility to recover the files. Go to this link for a step-by-step procedure and software references (free). http://www.ehow.com/how_4461259_restore-deleted-files-sd-card.html
Posted on Feb 01, 2010
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
Hi i own a RCA digital voice recorder model# rp5030A i can not figure out how to delete recordings
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B, C , D or )
2. Select file.
3. Press ERASE once and DELETE will blink on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B, C , D or ).
3. In Stop mode, press FORWARD continuously until "ALL" appears on the display.
4. Press ERASE and "DELETE" will blink on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Tip: File numbers that come after erased one will be moved forward by one automatically.
See page 12 for more info: http://www.rcaaudiovideo.com/docs/common/RP5030/RP5030_OM.pdf
Dec 29, 2012 | RCA RP5030 Digital Voice Recorder
Pictures Lost???
Get an inexpensive card reader and try to download the pics to a folder you create on your desktop.
Nov 30, 2009 | Olympus SP-500 UZ Digital Camera
Returning erased files to the memory stick
Because it's a one-way street. From camera to computer works...from computer to camera doesn't.
Oct 28, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
How did my pictures get deleted by formatting the card?
when you format something it deletes everything leaving it how it came from the factory, it's possible that you had corrupted files and the camera advised to format, next time cancel
Aug 04, 2009 | Sanyo VPC-E760 Digital Camera
The camera erased all my pictures and it will not format the disk
Have you tried to put the card in a card reader and connect it to your computer? Card readers can be purchased at just about any store that sells electronics or camera supplies. They cost around $20 or less. You put the card in the card reader, attach it to your computer and click on start and then my computer.You should be able to see something that says digital media or mass storage. Highlight that and that right click. It should give you the option of formatting the card. It will erase everything and format it for you. Then you can try it in the camera. If this doesn't work then it should be looked at. Good luck
Jul 31, 2009 | Cameras
Can I recover erased pictures from an Ixus 870?
You can connect camera's memory card to computer, then download this picture recovery program which is outstanding among all picture recovery software.
http://www.001-software.com/picture-recovery/
Jun 17, 2009 | Canon PowerShot S230 / IXUS 179 Digital...
I erased all my photos
hi, once formatted it is impossible to get and data back. sorry
May 19, 2009 | Canon PowerShot A530 Digital Camera
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
Canon PowerShot S51S Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
