Question about Thermos Quick Set Gas Grill 4000
This is for the Thermos Millenium 4000: I need
This is for the Thermos Millenium 4000: I need the ignitor, burner 21 inch, burner cover. Where do I get at the best price
Ive replaced the gas tank and make sure valve is on tight but the flame is still weak!?
Posted on May 28, 2010
I have thermos quick set gas grill--are the lava rocks supposed to cover the burner cover
They should cover the tray above the burner so the burner can heat them .
Apr 20, 2012 | Thermos Quick Set Gas Grill 4000
I have a used Thermos 2000 Millenium Gas Grill. Is there supposed to be charcoal on top of the burner cover? The charcoal was there when I got the grill. Thank you.
That's not charcoal or shouldn't be. It's Lava Rock Briquettes. If you want to replace or refresh them. you son find the, at most hardware stores and homes centers that sell grills and accessories.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Sep 04, 2011 | Grilling
How do I change a thermal coupler on a laars lite 2 pool heater?
ther is no thermos coupler in lite 2 it has a ignitor depending in what vintage 2 white wies go down either to a box in bottom middle or to lower-right burner check fuses in black cases first if ok change ignitor if bad change fuses
Aug 24, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
How does the burner connect to the regulator for the thermos Millennium 4000
In most grills, the burner is "seated" on the valve, the valve is attached to the manifold, and the manifold is connected to the gas hose and regulator.
Jul 02, 2010 | Thermos Quick Set Gas Grill 4000
How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Jan 18, 2010 | Stoves 600SiDOm Gas Kitchen Range
Viking Professional VGIS 360-6BDSS (~10yrs old)- Oven won't come up to temp. The right oven burner ignites and the flames are a 1.5-2 inches long along the burner. The left burner will eventually ignite...
Your second ignitor needs replacement. If you can measure the current to the ignitor, it should be at least 3A. I usually replace this kind of ignitors with a Maytag ignitor, which is slightly shorter. The original one, part number is PB040001 has been discontinued.
Maytag ignitor part number is 12400035
If you buy it from the link above, coupon "New10" chops 10% off.
Oct 24, 2009 | Kitchen Ranges
THE BURNER RUSTED. nEEDS REPLACEMENT
Dismantle the burner and remove. Take to a local BBQ retail shop, LOWES or Home Depot and look for a matching dimension replacement grille from GRILLE PRO
Sep 13, 2009 | Thermos Quick Set Gas Grill 4000
How to install ignitors on Viking Range
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range
Sep 07, 2009 | Viking VGIC485-6G Gas Kitchen Range
Dynasty range, oven does not heat up enough
30 inch oven has only one oven tube, 36 inch oven has 2 burners in it, most comment is the oven ignitor is out. If you have 2 burners, I'll change both oven ignitor at the same time, because they worked together. also check the oven tube, if it is corroded at the ignitor area, change the burners. Have fun.
Mar 22, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Thermos Quick Set Gas Grill 4000 Logo
842 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
