Question about Cameras
Canon ZR200 memory card say ''card error'' when inserted. Card is not locked. I have formatted it. Have used 3 different sizes of cards. Sometimes it will say ''card error'' then start working a couple of days later as if nothing was wrong. Last card used worked for 13 pics then started ''card error'' next time I turned it on. Currently it just says ''card error'' all the time.
  • Lizz Black
    Lizz Black Feb 01, 2010
    I had already done the rubber thingy.(Did that one time before and it worked)
    But I did the alchol and rubber cleaning 2 times. Still says "card error".
    Can you think of anything else?
    If not, thanks for your help so far!
  • Lizz Black
    Lizz Black Feb 14, 2010
    Got it fixed! Someone, somewhere said they gave the camera a whack and it worked. Well, guess what --- after akk the work I did --- I gave it a whack on both sides and it has been working great since then.
    Go figure.
    Thanks for all the help.
    RottenRotti
  • 583 Answers
Sounds like the contacts for the cards are dirty. Turn off the camera and remove the batteries before doing the following.
Try taking a piece of card stock (or a manilla folder) and cut it to the size (width only) of your memory card. Fold it to make it thicker. Wet the creased end with rubbing alcohol. Now gently insert the creased end into the memory card slot and move it in and out to clean the contacts. Remove and blow out with a can of compressed air to dry. Let sit a few minutes and then your cards again. You might want to clean their contacts as well with a clean rubber type eraser by gently rubbing the contacts on the cards.
Posted on Feb 01, 2010
  • Mark Tidwell
    Mark Tidwell Feb 08, 2010
    If you only had one card, I would suspect the card has been wore from use. But since it is multiple cards and I assume they work in card readers, it can only be the one common object and that is the card slot in the camera. It is possible that the contacts within the slot have lost their "spring" and not making contact with the cards as you insert them. If it is a fairly expensive camera, then I would look into the cost of having the slot repaired. Most camera shops can have it fixed for you at a fairly economical price.
  • Mark Tidwell
    Mark Tidwell Feb 15, 2010
    I'm glad you were able to fix it. I would've never told you to "whack" it on the sides. Happy picture taking!
I got cannon power shot sx130 is it reads memory card error the memory card is not locked but the eject button is not working how to fix this problem. thanks
Try to switch off the Camera and restart it gain. Again, Sometimes, its due to some auto-run software running in the card which prevents that from ejection. You can try to even format the card in the camera itself. That may work also.
As a last resort, check up your camera and get that memory card removed out of your Camera.
Feb 16, 2015 | Canon Powershot SX130IS Black Digital...
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Mar 19, 2011 | Canon PowerShot S51S Digital Camera
It says memory card error.i took out the sd card and it was not locked and it still says memory card locked. i formated the card also and it still says the same thing.
How big is its capacity ? Some device can only support memory card at certain maximum capacity, if you inserted card with higher capacity it wouldn't able to read it and it would say "card error".
Try to insert another card with lower capacity. i.e. if you have got "card error" notification for inserting 4 Gb memory card, try to insert 2 Gb card
Hope this help, and if you think its helpful RATE please.
Jan 28, 2011 | Canon PowerShot SD790 IS/ IXUS 90 IS...
After inserted A new batteries in the screen shows card locked how I can fix that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
May 15, 2010 | Canon Powershot SX110 IS Digital Camera...
When I put the memory card in and turn on the camera, it keeps saying memory card error.
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 03, 2010 | Canon Power-shot S1 IS Lens Converter
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
I have a canon powershot sx110is and when i turn it on it will not take any pictures but instead gives the message "memory card error." When I put it to the display mode it says the same message plus...
First see if the camera will work without the memory card installed. Then format the internal memory using the camera's setting as described in the manual.
Then turn OFF the camera and insert the sd card. Turn on and reformat the card too.
Make sure you have NEW batteries or sometimes things go flakey.
Dec 22, 2009 | Canon Powershot SX110 IS Digital Camera...
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
Memory card error
Try a smaller memory card size . I was trying to install a 4gb card and the guy at Kmart told me to try a 1gb card and that fixed the locked card error . No where in the instruction book did it address this problem.
Sep 24, 2007 | Canon PowerShot A530 Digital Camera
Cameras Logo
236 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
