My toshiba laptop was power on but no sceen display,How will i open my computer so that i can view my files?
  • 152 Answers
Open your harddisk case it is SATA harddisk so you can attach it any desktop motherboard or external usb hdd drive and backup your file
Posted on Feb 01, 2010
Laptop sceen black
If everything else is working, hook a spare monitor to the video output, if picture okay! the inverter board just below the screen is more than likely faulty, or the backlight behind the display has failed, but if both show the same symptom it is the video graphics card usually built into the motherboard, I suggest a computer repair shop to address.
May 05, 2012 | Toshiba Computers & Internet
Computer will not turn on
Toshiba Satellite PSAFGU-00L002 is also known as Toshiba Satellite A215-S7437.
http://www.superwarehouse.com/Toshiba_Satellite_A215-S7437_Notebook/PSAFGU-00L002/po/1506166
Power Button Board, for the Toshiba Satellite A215 series of Notebook PC's,
http://www.zkarlo.com/selected-zkarlo-part/power-board-p3326.php
The A215 series is just a fancier version of the A200 main series.
This is a pictorial disassembly guide for the A200/A205 series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Follow Steps 1 through 17. You can click on any photo to enlarge.
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery.
2) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, you can substitute with a clean egg carton.
Label each egg holder.
SOME screws look VERY similar to other screws. DO NOT mix them up.
3) Follow Anti-Static Precautions.
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
It would be best to buy, and wear an ESD wrist str-ap, and have the alligator clip attached to a good ground source.
(I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case)
{Electro Static Discharge. One example of an ESD wrist str-ap,
http://www.radioshack.com/product/index.jsp?productId=2103245 }
This is a link to a free Service Manual, for the Toshiba Satellite A215 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down a little to the subheading - Satellite A10. (A10 is in blue)
Scroll over, and click on the blue - A215
The service manual is in PDF file form. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { A215 } it may take up to 30 seconds, before the first page comes up.
The page number box is at the top of the PDF file, to the right of the Down Arrow. The Zoom In, and Zoom Out icons, for viewing size, are to the right.
The Bookmarks Menu is to the left.
Page 179 starts the replacement procedure for the Function Button Board.
In the Bookmarks menu it is;
A) Left-click on the + sign to the left of - Chapter 4 Replacement Procedures
B) Scroll down, left-click on 4.20 Function Button Board
Display Assembly, Strip Cover above Keyboard, Keyboard, and Top Cover, need to be removed in order to access, and replace the Function Button Board.
You can click on each individual area, Keyboard (Page 152), and Display Assembly (Page 155)
Removal of the Top Cover is covered in Display Assembly.
From your diagnoses of the problem, I also concur with Function Button Board replacement. (Power Button Board)
Would appreciate if you would post back with your findings, in a Comment.
Regards,
joecoolvette
Jan 15, 2012 | Toshiba Satellite Computers & Internet
After I power the computer the system does not appear on the sceen
This can be a few things. The display could be out or the laptop is not running or the hard drive is acting up or even the operating system needs to be repaired or re installed.
If you see anything and then it stops it could be the drive or a software or os problem. If it does nothing and no display then you could have a memory or ma inboard problem. If it makes sounds like it is running but no display your display might be the problem usually the back light.
You need to describe what it does or doesn't do when you try to start it in more detail. Then someone will be able to narrow things down and give you a fix.
Sep 01, 2011 | Toshiba Satellite A135-S4527 Notebook
Why won't my wireless modem turn on it is a toshiba laptop there is no switch to turn it on and Fn F8 doesn't work either. had it working when i bought it 3weeks ago and now it is shut off and don't know...
Hi, there are (4) areas to view to try, and fix the problem. 1. From the Desktop, click on the "Start button." 2. In the Search box, Type: modem. 3. Click on the Modem "item" that appear in the search. 4. You may be required to provide information, to "setup" the Modem. 5. Next, the location to go to is the "All Programs" start menu, click on the start button to open, scroll to find: the Accessories file, select to open the file. 6. View to see if you have the Windows Mobility Center; function, if so? Open the program. If not? Skip the action. 7. Next go to All Programs, scroll to find the "Toshiba" file, open the file, select Utilities, click to open; if you see the Toshiba Assist icon, open, and click on (Toshiba Hardw...), select the LAN button, and "check" the Wireless Communication Switch, (on / off), click, "Apply and OK!" 8. Go to the Toshiba file once again, and select; ConfigFree, follow all the instructions. 9. Click on the Start button, in the menu, in the (right, pane) select, Connect To: Follow all the instructions afterward. 10. "To finalize all applications, changes and "Updates!" Restart the computer" If this solution helped? Rating Feedback, is appreciated. "Thanks!'
Feb 19, 2010 | Toshiba Satellite L505-S5966 Notebook
Blank sceen
ok
when u power up the computer press F8 key then u see safe mode and other menu then enter in enable vga mode then change screen resolution to 1024*768
May 09, 2009 | Toshiba Qosmio G15-AV501 Notebook
Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Dec 01, 2008 | Toshiba Satellite 1115-S103 Notebook
Laptop toshiba
may be your user profile is corupt.
check in C:\Documents and Settings that there is defasult user.
but firsr open my computer then goto tool then folder option.
then view then enable show all fils and folders and show system files.
Nov 01, 2008 | Toshiba Computers & Internet
Sceen
try to do difragment of screen that may be solve your problem...
there is one megnet button in configuration of monitor.
Aug 22, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
