Question about RCA Televison & Video
Writing on the screen is fuzz. can this be adjusted to sharpen the writing?
  • RCA Master
  • 1,213 Answers
On the rear of this TV...if it is an RCA....there are two potentiometers. You do not have to remove the back cover. The top button is your focus. Try not to move the lower button as this is your screen voltage! Mark either of these with a permanent marker first, so you can return to the original setting. All other TVs, please remove the cover and use great caution to perform your focus!
Posted on Feb 01, 2010
Sharpening blades for qualcast 35s
With a cylinder mower the sharpness of the blade is only part of the concern. The fixed blade is like one of the blades of a pair of shears and each "blade" of the revolving cylinder acts as the other.
As long as only grass is being cut (no stones) the blades will last a long time with only occasional adjustment to the fixed blade as per instruction manual.
After much use or in case of damage the fixed blade will need replacing or sharpening. If it is badly worn it will need removing and sharpening by a specialist with the correct equipment but otherwise the light application of a file, stone or a patent sharpener and then readjust the blade per manual.
When eventually the cylinder becomes worn or sustains damage it must be removed and machine trued and sharpened using a lathe or similar.
An accurately sharpened cylinder and a true and sharp fixed blade correctly adjusted will consistently cut paper across the complete width of the blade when turned by hand. A competently sharped and adjusted cylinder mower will cut the thinnest tissue like the finest scissors without binding.
Aug 18, 2016 | Health & Beauty
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
What is a pencil sharpener?
A pencil sharpener is "a device for sharpening a pencil's writing point by shaving away its worn surface. Pencil sharpeners may be operated manually or by an electric motor." (wikipedia)
Oct 06, 2013 | Office Equipment & Supplies
My HP laptop starts with a white screen then fuzzes sometimes in between
Try to remove your LCD monitor check all connector must be connected properly, sometimes this happen if connector got lost contact.
If problem persist contact advance knowledge in trouble shooting Laptop monitor. This problem occurred when the bulb of LCD got Trouble.
Jan 14, 2013 | HP Computers & Internet
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
Why is my andis t out liner not cutting nice and clean
You need to have your Andis T sharpen and adjusted for power, Check out Manny's Sharpening for their mail order service on sharpening. Manny's Sharpening specializes on Andis T-Outliner.Manny's Sharpening They will hook you up on that T, You can request on how you want the blade set for Line Ups or Fade cuts and even shave. They do it right Manny's Sharpening been around for over 20 years and they have a good rating on the net.Andis T Video
May 13, 2011 | Andis T-Outliner Hair Trimmer
How do i sharpen the blades on my andis t-outliner, and give it whats called the New York, or east coast ...??
On the Andis T-Outliner trimmers I recommended sending it to a pro, these trimmer need to be adjusted correctly and the blade needs to be sharpen by an expert. at Mannys'Sharpening they have 20 years in the sharpening b's and they are experts in Andis T's they specialize on them. Manny's Sharpening has a mail order service they charge $15.00 to service & sharpening your trimmer plus the return shipping is free. the way you pay is via email via PayPal. and they will hook you up they way you want that trimmer blade to cut. check it out at Mannys-Sharpening.com also check their reviews on yahoo local.
May 10, 2011 | Andis T-Outliner Hair Trimmer
Chainsaw does not cut straight, veres off at an angle only happened since adjusting the chain ,is there an adjustment for this?
Typically this is a problem with sharpening the chain....if the chain has been sharpened unevenly (different angles on the cutters) it will drift to one side. Also most people tend to be more comfortable sharpening one side than the other and the teeth on that side will get worn faster.
As long as it is that right chain for the saw / bar and it is sharpened evenly it should cut straight.
There is no adjustment per se.
Take care.
Dec 06, 2010 | Garden
Samsung plasma red fuzz on black screen
Most likey its a bad panel, you can try adjusting VS voltage on Y main board, if this is to complex you will need a tech
Aug 09, 2009 | Philips 42PF9630A 42 in. Plasma Television
My samsung flatscreen picture is starting to look really fuzzie in some areas on the screen it is almost like a picture on top of a picture.
fuzz balls in some areas on plasmas can actually be adjusted out on the Y board first mark the controls with a sharpy then watch the fuzz spot as you turn the controls a little to see which one clears up the picture. the back needs to be off and the Y board is laft side when you are facing the back
Jul 24, 2009 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
