Trying to connect cable box to jvc dvd recorder and samsung hdtv tv if i follow instructions and connect hdmi ord to recorder dont get anythin g on tv cant get hdtv only av if i connect hdmi cord to tv no dvd recorder help
  • schirle1116 Feb 01, 2010
    connectng cable to jvc dvd recorder to hdtv cant record and getting no tv pic with hdmi cord plugged into recrder from ca ble as instructed
  • 382 Answers
I'm not sure where you are located but in NA HDMI uses HDCP which is high-bandwidth copywrite protection.
Basically what this means is that the HDMI signal is encoded and releases keys to unlock the signal. Every unit using HDMI must be HDCP compliant or else it will not work at all.
What this means is you cannot record an HDMI signal, you can only record using base-band video. You can watch the content straight off the cable box but you cannot record the Hi-def feed onto a DVD. You can only record using the analog connections.
If you only want to watch programs then I would suggest getting a PVR cable box instead.
If you only want to use the DVD recorder as a DVD player then connect it with HDMI directly to the TV and connect the Cable Box directly to the TV using HDMI and switch inputs on the TV when going between the two sources.
Let me know exactly what your wants/expectations are of the set-up and I will go into detail about the best way to connect and use everything.
I hope this helps,
Cheers!
Kevin
Posted on Feb 01, 2010
  • Kevin Braid Feb 01, 2010
    Ok first try the DVD directly into the TV.
    Can you see the DVD?
    Now plug the Cable Box into the DVD recorder using the analog audio and video. Make sure the cable box is only plugged into the DVD recorder and not the TV as some units will only output one video mode at a time.
    Now change the input on the DVD recorder to line in (or whatever the Cable Box is plugged into).
    Can you see the Cable Box on the TV now?
Need to attach dvd/vcr player to cable box and hdtv
DVD/VCR will take inputs of either component BGR RW or composite YWR and will provide either composite or HDMI output. My suggestion is to take the "best output" from the cable box you can and use the HDMI output to your HDTV. This will take the best your cable will offer and give your TV the best signal to use.
Cable box ------ to DVD/VCR ------ to HDTV.
Sep 04, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
HOW TO CONNECT IT TO MY CABLE TV.
Connect the cable box to the DVD Input 1 (on the back) or the AV 2 jacks on the front of the DVD recorder using a composite cable (Yellow - Red - White). Use an HDMI cable from the JVC DVD to your TV if it supports it. Otherwise use a component (red-green-blue) cable to the TV.
Mar 10, 2009 | JVC DR-MV78B DVD Recorder
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
I ahve a hdtv and a vcr how do I connect all three together and a diagram,please, Thanks joe
i dont know how to make a diagram but i will give the best instructions
make sure you follow these instructions so you will take advantage of your tv best possible picture if you hook it up some other way you will not get that great a picture
sat cable
coax from wall to box-use a hdmi cable only no other cable its pure digital connect to the out section on box and in section on tv
dvd
if dvd has hdmi out from dvd to in on tv the same as step one if dvd does not have hdmi then you will use commponent cables red green blue for picture and red and white for audio out from dvd to in on tv
vcr
since you cant record hd on vcr you will just hook it up with yellow red and white (composite cables)out from vcr to in on tv.
if done any other way it may work but not digital and not best picture available to you
Sep 09, 2008 | Televison & Video
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
