Question about Dell 922 All-In-One InkJet Printer
I've hooked up the printer, but its still failing
I just hooked up the printer, and error message reads "could not start print job.The usb cord is connected and I set the printer to default.
Error code says invalid pdl file
Uncheck the "Enable advanced printing features" checkbox under the Advanced tab in the printer's Properties page. I've observed this causes the print job to fail when I've attempted to print via USB cable. Also, any advice you read that suggests printing directly to printer isn't sound advice. You need to spool your job, or otherwise a large job that does not fit the printer's available memory (buffer) DOES NOT fail gracefully.
Mar 01, 2012 | Dell 3000cn Color Laser Printer
When i try to print something a window pops up that says "communication not available" ive tried restarting, unpluging the power cord and the usb cord...nothing seems to work
This problem could be caused by several factors - incorrect USB port selection, your printer is not set as your default printer, firewall, etc. This article in the Lexmark website: Communication Not Available' Error Message and Print Job Stalls in Print Queue will help you determine the cause and resolve your printing issue.
May 11, 2011 | Lexmark X2600 InkJet Printer
I am getting an error message: 0xc18a0206
Hi
This is the proper procedure andif this fails, take it in for service.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer. Source(s): Computer Analyst / Microsoft Certified
Feb 12, 2010 | HP Photosmart D7160 InkJet Printer
It says ink system has failed unable to print error Oxc19a0020
Hi
Thanks for using FixYa. The error Oxc19a0020 means ink system has failed. Try the following steps to troubleshoot the issue with the printer--
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Reconnect the USB cable, and try to print a print job from the computer.
    Also try this---
· Press the On button to turn the printer off.
· Unplug the power cord from the back of the printer.
· Remove all the ink cartridges.
· Wait two minutes.
· Plug the power cord into the back of the printer.
· Press the On button to turn the printer on.
· Install the ink cartridges when prompted.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing error
From your start menu, go to printers and faxes area. When this opens do you see your printer listed? Is it greyed out at all or maybe listed as offline? How are you connected tot he computer? Network, USB, or parallel port connection? If you see your printer listed and it has no other duplicate listings, right click the printer and go to properties, then choose the Ports tab. Verify here that the port selected witha check mark corresponds with your connection method. Example: If you are connected through USB, your selected port should say USB. Sometimes DOT4 ports will work for USB connections too. If you see this option, you can select it and hit apply to try it out. Try to print a test page after each applied change. Also, make sure that print jobs haven't built up in your queue by double-clicking your printer icon. If there is a queue of failed print jobs, select them and cancel. This might take a moment to complete. If your printer icon is greyed out, right-click it and un-choose the work-offline option and try it.
Mar 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Installed new computer - keep getting error - HP Photosmart C6150
Try
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer not working correctly
Sounds like a USB power issue. How many USB devices do you have plugged in? Unplug everything but your printer and see what happens.
Sep 26, 2008 | HP Office Equipment & Supplies
HP photosmart3210 printer problem error message
The issue relates to hardware of the unit ,
unit can not be recovered or is almost certain to fail again, however we can Attempt to Recover Unit Once .follow the steps below .
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Reconnect the USB cable, and try to print a print job from the computer.
9. If the error is still there replace the unit.
it might help.
Thanks.
May 17, 2008 | HP Photosmart 3210 Printer
Error messae appearin as soon as I turn it on
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  4. Disconnect the power cord from the back of the product and wait for one minute.
If these steps did not resolve the issue, contact HP technical support for assistance
Nov 15, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Dell 922 All-In-One InkJet Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
