Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Tv is loosing video and sound every couple of minutes then c omes back on
  • 135 Answers
Replace the lamp
Posted on Feb 01, 2010
Every few minutes the sound drops out for a couple of seconds. Tv is a Sony and I am watching via sky
Does the TV do this no matter the video source, for instance does it do it when you watch a DVD? If the sound is steady on other video inputs then the TV is not the problem.
Jun 28, 2017 | Sony Televison & Video
No sound
Sounds like a loose connection that has finally failed in the audio out circuit
Jun 04, 2008 | Hitachi 61HDX98B 61" Rear Projection...
Turn off protect mode tv
It sounds that the TV's internal circuit board has some loose solder terminals. You have to re-solder them. In most cases, these faults are related to main power supply regulator board.
May 15, 2013 | Panasonic 50 in. Plasma TV
34 " Sony Trinitron tv won't come on. Just blinks and sounds like it wants but I get nothing!
take a ome meter and check IC301 shorted to ground, IK video path is defective.........you can get parts @ Mats Electronics #1-800-628-1118.hope this helps...........
Feb 17, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have a Visio GV42L HDTV loosing sound on some channels
That's a broadcast signal issue not TV issue. If it was the TV all channels would be the same.
Aug 21, 2017 | Televison & Video
My 31GT740 tv's picture is taking up to 5 minutes to come on...
There is possibly a loose solder joint in the horizontal drive circuit. There is a little coupling coil just before the horizontal output that will get loose. This should not be real expensive to have repaired.
Oct 20, 2009 | GE 31GT740 31" TV
Samsung t.v. picture going in and out
it may sound like you have a input or a output problem if you have a video un plug it from the tv. and put your Aral strait to your tv that will tell you if your video is the problem not the tv.
Jan 07, 2008 | Samsung DLP HL-P5663W 56" TV
No sound
Hi, Probably you first have to determine if the "no sound" is the TV or your source (cable box). Try another source such as a DVD player hooked to the audio/video inputs of the TV, if still no sound then you have confirmed that it is the TV, if there is sound, then it is the cable box (in some cases it may be just the cables connecting the cable box and the TV; try wiggling it a bit, might just be loose). If it is the TV, go through the routine of the setup/menu; look for audio, stereo, SAP, etc, try different settings (pls log down original setting in case no change and you have to revert back). If all else fails, try the "thump test" this will help you determine if its a loose/cold solder problem inside the TV. Give your TV a good whack at the side, top or back, if sounds comes on even briefly, it's a loose/cold solder problem, if not then you probably have to have the unit serviced by a qualified professional. Good luck and kind regards.
Aug 26, 2007 | TruTech PLV16320 Television
Model 2780R intermittant Picture & Sound Failure
The set has loose power conections to the tuner and judging by the model it might have other loose conections in the chassis,the loose conections need to be resoldered and might not be easy to find,try taping the side of the set to see if it reacts while is doing the problem.Be safe and call a technician unless you are familiar with tv service.
Sep 20, 2006 | Sony KV-27FV16 TV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
