Question about Maytag MERH865RA Electric Range
A long rubber gasket fell out of the bottom of door
A long rubber gasket fell out of the bottom of our electric range door. It appears to be a the front window gasket. this is on model #merh865ras. What does it take to replace it. It appears that maybe just the removal of 6 screws and the front of the door should come off??
  • 725 Answers
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
I have a problem with my window i put it down one day and it fell down inside my door panel the side that is suppose to be under the rubber.
Remove the inside door trim and see what has gone wrong.
you may have jumped the rollers (if it has rollers) out of the track and it has dropped to the bottom
Not sure if you have electric windows or not but.
Jun 24, 2010 | 1991 Dodge Spirit
Replace boot gasket
Hello, Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversible, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everything. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Thanks
Jun 10, 2010 | GE WSXH208A Front Load Washer
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
The rubber gasket around the tub fell off on front loader
Open the door and reinstall the bellows (door gasket) onto the door lip. The metal ring clamps the bellows to the door lip. Start in the groove at the top and work your way down the sides. The spring part goes on the bottom (be careful not to stretch it too much). An extra pair of hands could help.
Let me know if you need more assistance.
Apr 02, 2009 | GE Washing Machines
Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Cleaning inside glass door, kitchenaid range
you do no tneed to remove the top to release the glass, yea aslong as the lower trim is removed then the only thing holding the glass, is the grease/sticky rubber gaket. lift up from the bottom slightly and twist out from the tabs. just be carefull when cleaning inner door glass, those "ridges in the paint, are just that paint, so dont use anything abrasive, youll ruin the finish!
Oct 30, 2008 | KitchenAid KGST307 Gas Kitchen Range
GE Profile range oven door
foil was just protective heat tape, there is a track across the bottom of door that is holding it up,
Mar 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
theres a bottom trim that installs from under the doorwith 3 phillips screws, this is what holds the door in place. it probably rests under the hanndlesupport and is held up by this strip, take a close look at bottom of door and you see the removable metal strip..
Mar 20, 2008 | Hotpoint RB787 Electric Kitchen Range
Maytag MERH865RA Electric Range Logo
101 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
