Question about Generic Memory Compaq Presario SR1215CL by HP AMD Sempron 3000+ 512MB 120GB CDRW/DVD w/XP [Refurb] [MIN90] PJ506AA... (PJ506AAR) PC Desktop
Cpu powers on. Monitor goes to Windows XP and
Cpu powers on. Monitor goes to Windows XP and searches for program and then says no signal . Can you help
    Problem Solver:
  • 8 Answers
Dear, This is due loose connection of power cable
(which connect from CPU TO MONITOR). Just check your power, m sure ur problem would be fix out.
Posted on Feb 01, 2010
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
http://www.viewsonic.com/support/downloads/drivers/?prod_name=1912
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the viewsonic.com site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
Need help with items not turning on
then turn your monitor on first before turning the CPU
the problem is on your Power Supply
Apr 11, 2010 | Microsoft Windows XP Professional for PC
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
I have a dell desktop that my buddy drought to me and I was gonna put a new windows xp os on it and the monitor will turn on then goes into power saving mode??
replug your cables and wirings inside your CPU, if your using a Video card and it goes power saving mode, use the on-board video card if you have, if you dont have try using another video card to isolate the problem.
Feb 24, 2010 | SVA-USA 9005S Monitor
PC shuts down while running Windows
Attempt to boot the machine in Safe-Mode.
While powering up continuously hit F8.
You will get a Boot Option Menu, Select Safe-Mode boot
If you can get into safe-mode I would suggest to try doing an online scan, as it sounds like your issue could be related to malware:
www.trendmicro.com/housecall
Let us know
Good luck
Apr 15, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
LCD monitor signs "no signal" on eMachines t3418
E-machines had had a long history of bad power supplies. I've seen many of these machines go bad and when they do they take out the video chip (Nvidea) with it, usually shutting down the whole machine. I've never seen one operable. You might be able to insert a video card.
Mar 23, 2009 | E-Machines eMachines Monitor E15T4
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
"No Signal" on monitor after boot
hi try to use different slot on your motherboard see if that helps if not try different video card...if that didn't help it might be your motherboard that went bad
Aug 23, 2008 | HP Pavilion a400n (DQ173A#ABA) PC Desktop
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Computers & Internet Logo
70 people viewed this question
Top Generic Memory Computers & Internet Experts
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
