Question about Optoma EP737 Multimedia Projector
How can I check the used hours of the lamp?
I cannot seem to find how I can check the used hours of the lamp of my Optoma EP737.
Press buttons up-up-left to go into service mode, there you see the lamp hours, succes
(jojoplan@kabelfoon.nl)
Posted on Apr 02, 2009
I have a Optoma HD80 and the bulb has about 450 hours on it. I cleaned the projector, unpluged it for several mins and still turns off after starting. If the bulb has only 450 hours on it, why should I...
hi,
You have to check the bulb first. Its not the matter of how many hours you have used it. just check the lamp. may be it burned out. Its only a bulb it can burnout at any time. also check the lamp colling fan is working or not. if it is not working the same problem can occur.
ok
Feb 06, 2011 | Optoma HD80 Projector
HD20 switches on by itself
the projector will shut off when the lamp hour count reaches expected lamp life. It will restart only long enough to read the hour meter again then shut it's self off again. You can manually reset the hour meter to continue using the same lamp. Good luck.......
Aug 02, 2010 | Optoma HD20 DLP Projector
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Apr 12, 2010 | Optoma H30 Multimedia Projector
Lamp goes out after a few minutes
my 3m projector switches off in 15 seconds indicating the lamp indicator, as the lamp has not been used enough
Mar 25, 2010 | Optoma HD80 Projector
How can you tell how much lamp usage is left
go into the menu settings and look for lamp timer. should give you # or % of hours left.
Nov 09, 2009 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
Optoma ep 706, lamp lights on,replaced lamp, still not working
moz-screenshot.jpgmoz-screenshot-1.jpghello,
This is an unfortunate incidence and i will send you the serviceable manual of your projector if you can send me your contact email address to my email.Yes ,there are instruction to follow to replace lamps in projector if not you might miss it. First you must confirm that the lamp is OK from the vendors you purchase before anything.
Bye.
anytony2004@yahoo.com
Aniekeme Anthony.
I
Jan 21, 2009 | Optoma EP706 DLP Projector
EP 757 Intermittent powering down
Pls check if the lamp is not so old that is giving the same problem. If lamp is almost new, then you can have a check with the Ballast unit card and then the loose connection in the Power supply or may be overheating and tripping.
Viren
Nov 18, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
Optoma ep 753 will not light
you can just open the lamp and see the condition of the inner tube only. otherwise you have to replace the lamp and run it.
Viren
+919814903739
Nov 17, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
Open Questions:
Optoma EP737 Multimedia Projector Logo
300 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
