Question about Yaesu POWEREX MH-C500Y Charger for FRS radios (VXF-10)
Lock function Hello, I have put my VX-2 transmitter in lock mode without knowing how, and don't know how to unlock it.
Reset the transmitter.
Posted on Feb 19, 2008
How do you reprogram a new key for a 2000 Buick park avenue?
Transmitter Programming
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. Up to four transmitters may be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly.
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Use the scan tool Remote Function Actuation Special Function: Program Key Fobs in order to place the remote control door lock receiver into Program Mode. The doors will lock and then unlock in order to confirm program mode.
  4. Important: The scan tool must stay connected until all of the transmitters are programmed.
  5. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 15 seconds, the doors will lock and unlock in order to confirm the programming of that transmitter.
  6. Repeat the previous step in order to program up to 4 transmitters.
  7. Remove the scan tool.
  8. Operate the transmitter functions in order to verify correct system operation.
Apr 12, 2016 | Buick Cars & Trucks
How to program keypad 2004 buick
ere is the process as per GM. Remember that all your key fobs must be programmed at the same time since once you begin this process the truck erases all previous fobs.
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to 4 transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
Jul 05, 2014 | Computers & Internet
Doors dont lock with secrity fob
The receiver for the fobs is located in the rear hatch, and it needs to be reprogrammed to the fobs. Try the following procedure;
that transmitter.
7. Repeat the previous step to program up to four transmitters.
keyless entry transmitter mode.
system operation.
Sep 05, 2012 | 2004 Chevrolet TrailBlazer
Horn honks doors lock be self
does this help? look in owners manual for how to turn "on or off" the auto lock feature.
Automatic Door Lock/Unlock
The automatic door unlock function is a vehicle personalization feature with the following 3?programmable modes of operation:
1. All: All of the doors will automatically unlock. 2. Driver: The driver's door will automatically unlock. 3. None: The doors will need to be unlocked by a door switch command or by pressing the the lock button on the RKE transmitter. The All or Driver modes may also be programmed as to when the automatic door unlocking will occur.
1. Key Off: The door(s) will unlock when the key is turned off. 2. Shift to Park: The door(s) will unlock when the vehicle is shifted into P (Park). The delay lock function may be enabled or disabled. When the function has been disabled, the doors will only lock by a door switch command or by pressing the the lock button on the RKE transmitter. When enabled, the doors will not lock until five seconds after the last door is closed.
Oct 21, 2011 | 2007 Chevrolet Malibu Maxx LTZ Hatchback
We own a 2000 Pontiac Grand AM, 3.4 liter, 2 door coupe with front wheel drive and recently replaced the transmission and now can't find our key set. Great start We hired a local Lock Smith who...
You can purchase new Remote Keyless Entry (RKE) transmitters from the dealer or you can order them online at the web sites listed below or several others. Your vehicle provides for programming the RKE transmitters without the use of a scan tool. Follow the instructions below.
2000 PONTIAC GRAND AM RKE TRANSMITTER PROGRAMMING
WITHOUT A SCAN TOOL
1. Close all vehicle doors. Remove key from ignition lock cylinder
NOTE: STEPS 2 AND 3 MUST BE COMPLETED WITHIN 25 SECONDS OF PRESSING THE DOOR UNLOCK SWITCH
2. Press and hold door UNLOCK switch. While holding UNLOCK switch, insert and remove the key in the ignition lock cylinder twice. Do not rotate the lock cylinder.
3. Insert the key a third time, leaving the key in the lock cylinder. Keep the lock cylinder in the LOCK position for the remainder of the procedure. Release the door UNLOCK switch. The chime will sound 3 times to signal that the programming/diagnostic mode is active.
4. Press and hold LOCK and UNLOCK at the same time on the RKE transmitter for approximately 4 seconds. The chime will sound 2 times signaling that the transmitter has been programmed.
5. Repeat step 4 for each transmitter being programmed. (You can program up to 4 transmitters.)
6. To exit program mode, turn the key to the RUN position then back to the LOCK position and remove the key. Your transmitters should now work to lock and unlock your doors.
2000 Pontiac Grand Am Transponder (direct links)
- autotransponder.com
-keylessremotes.com
-ikeyless.com
Jun 10, 2011 | Pontiac Grand Am Cars & Trucks
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
I LOST MY CHEROKEE CONTROL REMOTE ALARM, I BOUGHT A NEW ONE BUT ITS NOT PROGRAMMED AND I WOULD LIKE TO HAVE SOME HELP TO SOLVE THIS PROBLEM. CAN YOU TELL ME HOW TO PROGRAM IT. IT IS A CHEROKEE LAREDO...
NOTE :PLEASE READ INSTRUCTIONS FULLY BEFORE ATTEMPTING TO PROGRAM TRANSMITTERS.
Program Method A (Customer Program Method)
1. Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
2. Turn ignition to run position. (Allow ignition chimes to stop).
3. Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6. Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
NOTE :(FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP # 6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
7. Repeat steps 5 through 6 to program additional transmitters.
8. Turn ignition to OFF position. Transmitter programming mode v/ill discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
Program Method B (Customer Program Method)
1. Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
2. Turn ignition to the run position (Allow ignition chimes to stop).
3. Using original transmitter, press and hold the [UNLOCK] button on the transmitter for between 4 and 10 seconds.
4. Continue to hold the [UNLOCK] button and press the [PANIC] button. A chime will sound to indicate that the transmitter programming mode has been entered (Allow 3 seconds for chime to sound).
5. Press a button on all transmitters to be programmed into the system including any previously programmed transmitters; a chime will sound when each transmitter has been programmed.
6. Turn the ignition to OFF position to exit the transmitter programming mode.
Program Method C (Dealer Program Method) *Can be used for any type transmitter.
3. Plug DRBIII to vehicle's 1-way data link connector.
4. Follow Service Manual and DRBIII instructions to program transmitters.
Program Method D (For use with AB vehicles not equipped with VTSS only)
1. Locate the dark green program enable wire connected to pin # 1 of the 16-way data link connector under the left side of the instrument panel.
2. Connect the program enable wire terminal to a good ground.
3. Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.
4. Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.
5. Repeat step 4 to program additional transmitter.
6. Disconnect the program enable wire from ground to exit program mode.
7. Turn the ignition to the OFF position and remove the key.
NOTE :REFER TO DAIMLERCHRYSLER MDS2 SYSTEM OR PARTS DEPARTMENT TO OBTAIN THE CORRECT PART NUMBER AND REVISION FOR SPECIFIED VEHICLE.
Dec 18, 2010 | 2002 Jeep Grand Cherokee
How do i program a new remote for my 2001 chevrolet blazer?
You may program up to 4 transmitters, using following procedure:
Transmitter Programming Procedure (No Tools Required)
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
May 06, 2009 | 2001 Chevrolet Blazer
I need to know how to reprogram a keyless entry remote for a 2003 nissan frontier..
IMPORTANT: Before entering programming mode, have in possession all of the
transmitters you will be using on the vehicle. Once you program the
transmitter, all previous codes will be erased from the memory. The other
transmitters will not be functional until you program the transmitters
again.
1. Close and lock all doors with the driver's side power lock/unlock
switch.
2. Insert key into ignition and remove it from the ignition key cylinder
at least six times within 10 seconds. Your Hazard
Lamps will flash if you have performed this step successfully. NOTE:
Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not
enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your
Hazard Lamps should flash. NOTE: Do not press
the button more than one time in the above step. If the button is
pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones),
unlock then lock all doors using the driver's side
power lock/unlock switch and within 5 seconds, push ANY button on the
next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing
transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock
doors using the driver's side power lock/unlock switch and open the driver
side door.
Apr 11, 2009 | 2003 Nissan Frontier Crew Cab
Keyless remote
Don't know for sure it will work with your but try this.
  8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Sep 25, 2008 | 2006 Pontiac G6
Yaesu POWEREX MH-C500Y Charger for FRS radios (VXF-10) Logo
167 people viewed this question
Top Yaesu Radio Communications Experts
Steve
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
