Question about Canon PowerShot SD110 / IXUS IIs Digital Camera
Canon Digital IXUS 9015 Is there a way to change form 180 to 300 resolution?
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
I have read that there seem to be many issues with no display on the LCD in playback or photo mode. What can I do to get this resolved? Thanks you. Greg
Posted on Sep 15, 2008
t00nz
  • 4738 Answers
SOURCE: my canon ixus 9015 digital camera has ben dropped
This might help with some examples. Although none are elph series, it should be very similar, except in miniature:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Jul 11, 2009
  • 11967 Answers
SOURCE: Hi, my Canon Digital IXUS 9015 was dropped last
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 22, 2009
  • 102366 Answers
SOURCE: hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
Posted on Jan 15, 2010
  • 4 Answers
SOURCE: canon digital ixus 850is card locked! message
.....Open your memory card........Adapter And see There IZZ a ThiNg named Lockand UNLOCk That!!!! i guEsS that woULd Work.....
Posted on Feb 21, 2010
Testimonial: "many thanks for unlocking my card Is is an 8g card expensive for a pensioner. it had just a few photos on it. Thankyou again Peter"
I can not use my time and date stamp
You'll need to change resolution to "Postcard" resolution(1200 pixel width) to activate date/time stamp (look for it in the menus). Unfortunately, that is the only resolution that date time stamp will work in, or show as activated/selectable in your menu.
May 30, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
Silver pannel that sits under the A/V OUT has fallen of the Cannon Digital IXUS 9015. I am wanting to source this pannel and screws x 2 to fix it. Any Ideas for a suplier in Australia
I simply googled Canon camera parts in Australia and received a few results.By the sound of your part,it will probably cost more to ship than the cost of the parts.Here is a link for a camera seller warehouse in AU although I do not see a parts category.Hang on I will look for more.
http://www.digitalcamerawarehouse.com.au/
Here are some repair centers in AU,they may sell you parts.
http://www.acecam.com/oceania2.html
Here is another shop in AU which may sell you parts.
http://www.andersoncamera.com.au/
Here is another possibilty.It is Canon NZ I think.
http://www.canon.co.nz/en-nz/About-Canon/Corporate-Profile/History
Good luck mate!(I am in America but have been to Perth).I would love to go back to AU for a visit someday.
Aug 01, 2010 | Canon IXUS 860 IS Digital Camera
How to change resolution?
Press MENU/SET. Use up/down-arrow to select the bottom item along the left edge. Use left-/right-arrow to select the desired resolution and press MENU/SET.
Jan 13, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My pictures are now coming out in low resolution -
You may have accidentally changed the picture quality setting. Go into the menu and change it to a higher setting.
Dec 21, 2009 | Canon IXUS 80 IS Digital Camera
I have a Canon Digital IXUS 9015, i was wondering where the setting is for black and white photos?
On the IXUS 900 you can not use black and white, although you can change it to black & white when you go to print it in the shops or on the computer in programs like adobe, zoombrowser or windows.
Oct 01, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
I'm looking for an instruction manual for a Cannon IXus 9015 digital camera.
Am unfamiliar with an IXUS 9015, but I think you really mean IXUS 90 IS? If so, the camera is known in the United States as the SD790 IS. You may download the manual directly from Canon at the following link:
http://gdlp01.c-wss.com/gds/0300000871/PSSD790IS_IXUS90IS_CUG_EN.pdf
May 03, 2009 | Cameras
Changing the photo resolution
Go to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=15262
and download the Advanced User Manual. It will give you instructions on setting the resolution for your pictures.
PowerShot SD850 IS / DIGITAL IXUS 950 IS Camera User Guide Advanced
Apr 14, 2009 | Canon PowerShot SD850 IS Digital Camera
English manuals for Canon digital IXUS 80 IS camera
You can download User Manual of IXUS 80IS in English form Canon Support.
Dec 05, 2008 | Canon Cameras
Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
806 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
