Cuáles Son Los CODIGOS PARA Ajustar la imagen de pantalla Curtis Mathes modelo cm27101s.
You have bad capacitors near the vertical IC. And you might have some one change the two horizontal caps as well. One is 250volts 2.2MF and the other is a 25volt 47MF. The caps near the vertical would include a 35 volt 100MF, two 50 volts 100MF, 50 volt .1MF, 16 volt 100MF and a 50 volt 10MF. If the fuse in your TV is good...you will not have to change any semi conductors [ICs].
Testimonial: "gracias si me sirvio su ayuda el condensador dañdo fue el de .1mf 50 voltios. gracias otra vez."
