Question about Olympus VN-4100PC Digital Voice Recorder
Screen shows ERR. I changed batteries and tried
Screen shows ERR. I changed batteries and tried pressing stop and erase button but nothng happens.
  • 8 Answers
You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Posted on Feb 10, 2010
Hello, I have a Paradigm T801 showing the error message ERR 40 Over Acceleration. Is there any easy fix for that problem?
Reset the machine and proceed wit this steps. God bles you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Oct 02, 2013 | Paradigm Exercise & Fitness
Trimline manual
follow this steps and fix i.t God bless you
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • Sponsored Links
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2gXuRx33v
    Oct 02, 2013 | Exercise & Fitness
    When I try to graph I get an err: invalid dim Note: This started happening after I changed the AAA batteries
    If you got the message while trying to draw a graph
    1. Press [2nd][Y=] (STAT PLOT)
    2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
    If message popped up while doing something else that involves lists or matrices, the length of lists may be different, or the dimensions of matrices may not be compatible.
    To Clear the lists:
    1. Press [2nd][0] (CATALOG)
    2. Press [PGRM] (C) to jump to first command that starts with c.
    3. Use arrow to scroll down to ClrAllLists, select it [ENTER]
    4. Calculator displays Done
    5. Start the new problem.
    To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
    When the RAM is cleared, the calculator is reset. The calculator resets itself after a battery change.
    Aug 14, 2010 | Texas Instruments TI-84 Plus Silver...
    Display screen flashes "CHK" repeatedly
    Hello.
    From FixYa Support: The "ERR" message reportedly means a memory error.
    Please NOTE: This solution will wipe out the memory.
    Press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again.
    Hope this helps.
    Apr 03, 2010 | Olympus VN-3100PC Digital Voice Recorder
    My Olympus VN-3100 voice recorder has suddenly stopped working! When I switch it on it flashes CHK for a couple of minutes then says ERR
    I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory (ERR means memory error). Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
    Dec 16, 2009 | Olympus VN-3100PC Digital Voice Recorder
    Mensage ERR, not start
    Press the DISP/MENU and STOP buttons at the same time for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
    Feb 15, 2009 | Olympus VN-4100PC Digital Voice Recorder
    "chk" error on screen olympus vn-4100 pc
    I had a similar sounding problem my Olympus VN-5000. I would turn it on, it would show "CHK" for a few seconds, and then "ERR." This persisted despite fresh batteries. The "ERR" message reportedly means a memory error. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model...
    Jul 20, 2008 | Olympus VN-3100PC Digital Voice Recorder
    Olympus VN-3100PC Voice Recorder Problem
    I fought with this machine for more than 9 months. And after playing with it today FINALLY got it working.
    This is what I did:
    Unscrew the faceplate. (Three screws. One is under the batteries).
    Put the batteries back on.
    Have the HOLD button on the normal position (down)
    Press and hold the MENU/FOLDER button together with the STOP button
    Press and hold the MENU/FOLDER button together with the DISPLAY button
    You will see a GREEN light, then a RED light then a "FOR" message will appear
    Press the DISPLAY button and after a few moments it will reset and ask you to enter the time.
    GOOD LUCK. Let me know if it works for you.
    HAVE A NICE DAY.
    Jul 15, 2008 | Olympus VN-3100PC Digital Voice Recorder
    The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in all the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again. Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
    Jun 25, 2008 | Olympus VN-240 Digital Voice Recorder
    I got a error on my olympus VN-3100PC
    yes the above solution ie by pressing "STOP" button and "DISP/MENU" button at a time is solved my problem showing "ERR" in VN 2100PC olympus voice recorder
    Jun 19, 2008 | Olympus VN-3100PC Digital Voice Recorder
    Olympus VN-4100PC  Digital Voice Recorder Logo
    505 people viewed this question
    Top Olympus Audio Players & Recorders Experts
    Greg Cann
    Greg Cann
    Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
