Question about Kenmore Washing Machines
Makes noise wont spin - Kenmore Washing Machines
  • Craig Harvey May 11, 2010
    Is this a front load or top load. need a proper model number.
  • 5,911 Answers
It sounds like you may have a broken motor coupling. This is a simple and inexpensive repair.
If the washer does not agitate or spin, but will STILL drain, the likely culprit is a broken motor coupling. You may also hear a loud rattling sound as the drive motor engages, but the tub no longer spins. Whirlpool uses a motor coupling in the place of a drive belt. It is located between the drive motor and and gearcase (transmission). This configuration is known as a "direct-drive" system. It is common for the coupler to wear out with age and break. Newer versions of this coupler are more resilient and resist breakage. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for the improved motor coupling is included in the link I provided. The average cost is about $10 - $15. You can purchase replacements at any of the following webistes:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. If you do not wish to order on line, take the part number provided and go to your nearest appliance parts retailer. This is a common part they should have in their in-store inventory.
If you have questions please post back with your model number (located on a nameplate along the wash tub rim under the lid). I hope this helps you.
Posted on Feb 01, 2010
Washing machine wont spin
if its belt driven the belt could have come off or snapped hope this helps. if possible state machine make and model then someone should be able to help you more
Oct 09, 2016 | Washing Machines
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Washer wont spin but makes loud noise
-could be a belt failure or some washmachines are directly coupled to the motor. - the coupling or belts are easliy replaced and visible if failed
Jan 12, 2012 | Washing Machines
Psp makes beeping noises and wont play any umds
mate make sure the case of your umd is correctyly placed and put your finger on the umd (where it spins) its like a little circle color silver move it with your finger and make sure it spins..
Mar 28, 2010 | Sony PlayStation Portable (PSP) Console
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Washing machine does not spin Whirlpool LLR7144
the motor coupling is probably broken. Especially if it wont wash either. Its probably just filling with water and then making noise but not actually washing. If its doing this than replace the coupling.
Jan 10, 2008 | Washing Machines
Motor wont spin
whats makes the noise on spin if motor not turning at all.. i kinda confused... I Would check lid switch and see if maybe that might be the problem.. havnt had a lot of experince with hover but most washers have lid switchs to prevent spinning when lida opened
Sep 02, 2007 | Hoover AAA140 Front Load Washer
Washing Machines Logo
48 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
