Question about RELIANCE ELECTRIC WATER HEATER
I LIVE IN A MOBILE HOME AND HAVE BEEN HAVING PLUMBING PROBLEMS, I HAVE HAD 2 PIPES REPLACED THAT HAD BURST AND THEN THE PIPES FROZE ON SAT AND I HAD A PLUMBER COME OUT AND DEFROST THEM, AND PUT A NEW HEAT TAPE ON, AND EVERYTHING WAS FINE. TONIGHT I HAVE A HISSING SOUND COMING FROM MY ELECTRIC WATER HEATER. I HAVE HOT WATER EVERY WHERE. SHOULD I BE WORRIED, AND WHAT SHOULD I DO?
  • 1 more comment
  • cheweyhopkin Feb 01, 2010
    I LIVE IN A MOBILE HOME AND LAST WEEK I HAD A PIPE UNDER THE TRAILER LEAKING AND THAT PIPE WAS REPLACED. YESTERDAY THE PIPES FROZE AND I HAD A PLUMBER COME OUT AND DEFROST THE PIPES AND PUT ON NEW HEATING TAPE . NOW MY ELECTRIC WATER HEATER IS MAKING A HISSING SOUND , I HAVE GOOD HOT WATER EVERY WHERE BUT THE TANK IS HISSING CONSTANTLY, DO I NEED TO REPLACE THE TANK, OR WORRY SOMETHING ELSE IS WRONG? THERE IS NO WATER LEAKING IN THE HOUSE AT LEAST.
    THANKS
  • cheweyhopkin Feb 02, 2010
    HI WAYNE WHEN I TURNED OFF THE BREAKER FOR ABOUT 2-3 MIN THE HISSING DID NOT STOP. TONIGHT IT IS NOT AS LOUD AS IT WAS LAST NIGHT. THERE IS NO WATER ON THE FLOOR LEAKING, I'M SORRY FOR MY POOR CLARIFICATION I HAVE WATER AT ALL FAUCETS, AND THE WATER IS HOT. THE WATER TANK WAS OUT OF WATER FOR ABOUT 12 HOURS WHEN THE PIPES FROZE ON SAT, IF THAT MAKES A DIFFERENCE.
    THANKS
    PAT
    yes, it gives me little peace of mind and i will just keep watching it
    President:
  • 1,901 Answers
Sometimes the English language can be confusing...
If you mean you have hot water LEAKING everywhere you should absolutely be worried and the leak needs to be found and repairs made, if it is another pipe or fitting. If it is leaking from inside the tank, it will need replaced.
If, however, you mean that you are getting hot water everywhere you have a spigot and there are no leaks and the hot water tank is hissing, that should not be a concern, unless it is a continuous hissing. When the elements kick on there will be a slight hissing sound, but it should quit after a while when the water reaches the temperature set by the thermostat.
Hope this helps. Thanks for using Fixya.
Posted on Feb 01, 2010
  • 1 more comment
  • Wayne Mineard
    Wayne Mineard Feb 01, 2010
    Sorry,
    Your second comment did not show when I answered the question. That is a problem on Fixya.
    If the tank is constantly hissing, I would suggest you have it checked out.
    Wayne
  • Wayne Mineard
    Let me ask you this:
    If you turn the breaker off to the water heater, does the hissing stop?
  • Wayne Mineard
    Wayne Mineard Feb 02, 2010
    Pat,
    The hissing could only be one of 2 things that I know of. One would be the heating elements heating the water. If you turned off the breaker and the hissing continues, the only thing that I know it could be is water. I just can't imagine water still coming in after 3 days though. Odd indeed. I would just suggest you keep an eye on it and at the first sign of any leakage have it replaced. If there continues to be no water leaking and your hot water is OK, I would not be too concerned.
    Wayne
  • 8,197 Answers
No you should not be woried you just have some air in the line by the heater. It will goaway after some water use.
  • Jyackle5
    Jyackle5 Feb 01, 2010
    So you have hot water at all taps or you have hot water allover like a leak. If you have hot water allover as in a leak then you need to replace the water heater.
I got a 2005 homestead rv and the water pipe broke or froze up how can I check and fix it
Water pipes in RV are Pex, which is not the same as PVC. Pex will freeze, but is designed to not burst when frozen. If you have located the broken pipe, it is simple to replace. Using a PVC cutter (looks like cheap shears) cut out the broken piece. Most likely the pipe size will be 1/2 inch. Pex comes in three different colors: white, red, and blue. Most likely the RV pipe will be white, but the color does not matter as the pipe is of the same material. Pex can be bought at stores like Home Depot, Lowes, or other hardware stores. The connector fittings can be bought at the same stores. The simplest to use fittings are the push-on self sealing fittings. There are cheaper fittings, but they take special tools to install them. The estimated cost of a 2 foot distance pipe repair is about $10 to $15. The time required depends on how difficult it is to "get to" the broken pipe.
May 28, 2015 | Water Water Heaters
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
Banging noise when hot water is turned off
plenty of water pipes particularly in older houses where pipes may not be fastened tightly or at all to the frame of the house suffer from what plumbers refer to as waterhammer. This can be fixed by installing a small device inline from your local plumbing shop. It can also often be solved ( I have found) by fastening you water pipes at closer intivals/more securely to your house frame. Hope this helps. Mine stopped doing it once the pipes were locked in place.
May 11, 2012 | Rinnai Water Heaters
I have a Bosch AquaStar AQ-125-BNG tankless water heater, and for some reason when it is heating the water, it seems to get exremely hot and the heat is radiated back into the cold water supply line and...
Tankless should never be installed with plastic pipe, PVC or CPVC etc.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Rattling AFTER water use, while heating
1) Rattling or clunking sound in pipes when water is shut off can be caused by lack of air chamber at the faucet. When moving water is suddenly stopped by faucet turning off, the forward energy of water suddenly stopping will cause pipes to shake. This is because water cannot be compressed. To stop this problem, each faucet has air chamber connected to pipes behind the wall. The air chamber is a simple pipe sticking up with a cap on it. The air chamber never fills with water, so a 'pocket' of air is contained inside the pipe. When water shuts off, the forward motion of water moves up the air chamber where it compresses the air which absorbs the energy, so pipes don't rattle or clunk.
http://www.crsupport.us/images/7b_build_const.jpg
2) Gurgling, popping sound inside tank is caused by sediment build up.
http://waterheatertimer.org/How-to-clean-sediment-out-of-water-heater.html
3) Add a comment with your experience so others with same-similar problem can benefit.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Mar 28, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have the exact same problem, house is only 6 years old, two handel faucet, Ive turned off the cold side to eliminate it, turn on hot and have to run at full blast and it takes a full 10 minutes to get to...
You have a clog in the water line?
Or a faulty check valve or mixing valve?
Add a comment and say how you fixed the problem, or add more information about size of pipes.
It seems like the cold water is getting into the hot water line somehow. There is no other explanation, as much as I can see from 800+ miles away.
If you have crossover on a single-handled faucet where the cartridge is bad, that can cause this problem.
Slab house can have plumbing in attic. It can be a chore to drop poly pipe down into walls, but it can be done with angle drill. Assuming walls are 8 foot high and pipes can be easily dropped to sink level where the sheetrock is removed and new pipes tied into sinks and tubs.
This kind of DIY project would take a couple weeks working a few hours each night when temps cool off, depending on size of house and number of affected faucets.
I live in Houston on a slab and ran my pipes in the attic when I built the house. Of course I worry about broken pipes collapsing the ceiling and filling the house with water, which happened to lots of homes one year when temps dropped to 4 below. I was in the painting business at that time, which was a boon to business for a few weeks.
Upvote the help.
And take advantage of fixya expert assistance live.
Dec 17, 2010 | Laing Thermotech Autocirc Undersink...
I HAVE A 50 GALLON 5YR OLD RICHMOND HOT WATER TANK SOMETIMES YOU TURN ON HOT WATER AND IT RUNS FINE.THEN ALLOF A SUDDEN THE WATER STOPS AND PIPES BANG.WE HAVE 44PSI COMING IN FROM CITY
What you're describing is "water hammer". This problem, left unchecked, can cause big problems for your home's plumbing. Water hammer is result of quickly shutting off the flow of water in your home. The faster the rate of water flowing when it is rapidly shut off can result in very loud banging. The banging is caused by the pipes shaking in the walls, ceilings and any place they aren't secured. This repeated shaking causes soldered and glued joints to weaken and eventually fail. The most common sources for water hammer are toilets and wash machines, but even quickly shutting off a faucet can cause it too.
An short article about water hammer is here. Below is a link to images of products designed to arrest water hammer and associated noise.
Please rate this reply - I hope this helps!
Dec 06, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
RELIANCE ELECTRIC WATER HEATER Logo
41 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
