Question about Texas Instruments TI-84 Plus Calculator
How do u store linreg(ax+b)as y1 on ur graphic calculater
  • Texas Instru... Master
  • 8,064 Answers
When you press [STAT] and right Arrow to highlight CALC you see two linear regression model [4:LinReg(ax+b)] and [8:LinReg(a +bx)]
If you select [4: ...] the command echoes on main calculator screen as LinReg(ax+b) and a blinking cursor
If you press [ENTER] you will get your equation, a, b, and r^2 if DiagnosticsOn command has been executed before. However you will not be able to see the line of best fit on top of the raw data scatter plot.
To save the equation of best fit in a function variable, ex Y1, you complete the command as follows
LinReg(ax+b) [VARS][=>][Y-VARS][1:Function][1:Y1]
The Y1 variable will appear on main calculator screen, and you have
LinReg(ax+b) Y1
Press [ENTER]
Screen display the equation, its parameter and its correlation coefficients (if so configured).
Press [GRAPH] to draw the line of best fit on top of the scatter plot.
Here are two screen captures to show you the equation and the line of best fit.
As you can see from the value of r^2, and the graph, a linear regression does not seem good.
Posted on Feb 01, 2010
  • k24674 Feb 01, 2010
    If you are interested in a more complete tutorial on linear regression on the Ti8xPLUS family of calculators, read this earlier post of mine.
Ti 84 plus silver edition will not fit a linear model to plotted points. when I use the function vars>stat>EQ>RegEQ it transmits incomplete data in to Y=.
Your data must be in two lists L1 (for x-values), and L2 (for y-values). This is the default setting. Open the STAT utility, go to the regression models. Select your model then press ENTER. The command echoes on the main screen. For example let the regression be something called LinReg.
On the main screen you see LinReg
Complete the command line as follows
LinReg L1, L2, Y1, ENTER
You see the statistics including the regression equation.
If you go to Y= Editor you will see that Y1 contains the regression equation.
If you have already drawn the scatter plot for your data, pressing GRAPH will superpose the scatter plot and the regression curve., and you will be able to judge the goodness of the fit.
Sep 28, 2013 | Texas Instruments TI-84 Plus Silver...
I have a TI-84 plus calculator. I enter data into a table (L1 & L2) and go through the steps to get an equation for the data. Next, I should be able to press VARS, move to Y-VARS, select FUNCTION,...
Your assumption
--Next, I should be able to press VARS, move to Y-VARS, select FUNCTION, then select Y-1 and automatically enter the equation into Y-1.-
is not correct.
When you press [STAT[>][CALC][4:LinReg(ax+b)] or any other regression model,the command echoes on the main screen. If you press [ENTER] at this point, the calculator uses by default lists L1 and L2 and displays the resulting equation without copying it in a Y-variable.
If you want to have the equation copied on a Y-function, you should modify the command as follows
LineReg(ax+b) [SHIFT][1: L1] [,] SHIFT[2:L2] [,] [VARS][>:Y-Vars] [1:Function][1:Y-1][ENTER].
Here, [>] stands for RightArrow. For any other regression model, use the appropriate command.
At this point, the command line should look like the following:
LinReg(ax+b) L1, L2, Y1
Press [ENTER] to calculate you get the same screen as when you do not save the equation in Y1, but if you go to the Y= editor or press GRAPH, you will see the regression line superposed on the scatter plot.
Jul 13, 2011 | Texas Instruments TI-84 Plus Calculator
How to find slope with two point coordinates on ti-84 plus calculator
Assuming your two point coordinates are of the form (x1, y1) and (x2, y2).
There are two possible methods:
You can use the slope formula which is commonly known as "rise over run." To do this: slope = (y2 - y1) / (x2 - x1) This means that the vertical distance covered by the two points divided by the horizontal distance covered by the two points is equal to the slope.
You can use your calculator's linear regression capabilities:
First step: Press the STAT button (next to the arrow keys toward the top right of your calculator).
Second: Select the first option, Edit...
Third: Under L1, enter your first x value, press enter, enter your second x value, press enter again.
Fourth: Under L2, enter your first y value, press enter, enter your second y value, press enter again.
Fifth: Press the STAT button again. Press the right arrow button to highlight CALC.
Sixth: Select the fourth option LinReg(ax+b).
Seventh: Press 2ND then 1 (L1 should show up on your screen). Then press the comma button (right above the number 7). Press 2ND then 2 (L2 should show up on your screen). Press ENTER.
Eighth: Once you press ENTER, several values will appear. The a value is the slope of the two coordinates.
Feb 03, 2011 | Texas Instruments TI-84 Plus Silver...
LinReg(ax+b)
One (or more) of the variables a, x, and b are in archive memory.
Press 2ND MEM to get into the memory management editor. Press 1 to select ALL. Scroll through the list. If any of those three appear with an asterisk to the left, navigate to that line and press ENTER to unarchive it.
Mar 05, 2010 | Texas Instruments TI-83 Plus Calculator
I own a TI-84 Plus (silver edition). Does this calculator have formulas built in for the least squares line so I might enter the data to get the values for b and m? If so will it give me the correlation...
Read this post. It answers all your questions and shows you HOW to do find your equation of best fit, correlation coefficients, etc.
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. To clear old data
  1. Press [2nd][+] (MEM) to open the memory management screen.
  2. Press [4:ClrAllLists]
  3. The command echoes on main screen, press [ENTER] to run it.
  4. Calculator displays Done.
B. Run the SetUpEditor command
  1. Press [STAT][5:SetUpEditor] [ENTER] ; calculator displays Done.
C. Turn DiagnosticsOn option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DiagnosticsOn option. To access the command
  1. You press [2nd] [0] (CATALOG)
  2. While the list of commands is displayed, press [X^-1] (D)
  3. Cursor jumps to first command that starts with D, dayOfWk(
  4. Press the DownArrow 9 times to reach DiagnosticsOn
  5. Select it and press [ENTER]
  6. Command echoes on main calculator screen with blinking cursor
  7. Press [ENTER] to set the option
  8. Calculator displays Done.
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. Enter the data
Press [STAT][1:Edit]
Type in the X values in L1 and the Y values in L2 (see picture 1)
To obtain the statistical results
  1. After you finish entering the data, press [2nd][Quit] to exit StatEditor.
  2. Press [STAT] and highlight Menu (CALC)
  3. In the list select [2:2-Var Stats]
  4. Command echoes on main screen.
  5. Press [ENTER] to calculate the stats
Here is what you get (with you data).
Notice the down arrow next to n=7. That means the results screen has more values. Press the down arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the satistics. Some of the values your are looking for are among the result. NOW it is you mission to identify what you need (I chewed all the work for you).
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have to perform a regression analysis.
Perform a Regression analysis
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. In this particular case, you have already decided to do a linear regression, and that is good for me. I do not have the time to take you through all of them. A linear regression it will be.
  1. Press [STAT] , highlight [CALC]
  2. In the list of regression models select [4:LinReg (ax+b)
  3. The command LinReg(ax+b) echoes on main calculator screen.
  4. If you press [ENTER] you will get you equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
  5. While LinReg(ax+b) command is still in command line, press the [VARS] key.
  6. Highlight the [Y-VARS] menu and select [1:Function], then press [ENTER].
  7. In the Y function variable list select [1:Y1]
  8. At the command line, you have LinReg(ax+b) Y1.
  9. Press [ENTER] to save the equation of best fit in Y1.
Here are your results.
The slope is a and the y-intercept is b. You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked to obtain.
Since you saved the equation in the Y1 function you can draw it. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
Drawing the scatter plot and the raw data on the same screen.
Regardless of the curve of best fit, you can draw a scatter plot as follows.
  1. Press [2nd][Y=] (STATPLOT)
  2. Select [1:Plot1...Off] to open plot1 configuration screen
  3. Use arrow to highlight On
  4. Use the down arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOTE: To navigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the Xlist is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearnce of the raw data point.
And here is your two graphs: the raw data scatter plot and the line of best fit on the same screen
Now, it is up to you to accept this model or to try another model.
Jan 28, 2010 | Texas Instruments TI-84 Plus Silver...
How do I use stat plot to graph a set of points?
1.Press [MODE], scroll to set Function graphing mode.
2.Press [STAT] [5:SetUpEditor], command is pasted in home screen. Press [ENTER]. Screen displays Done. This clears old values in lists
3. Press [STAT][1:Edit] to enter data.
Press [ENTER] after each number. Cursor moves to next row. After finishing the data of Listt L1, use arrow right and UP to the head of list L2. Enter the values in list L2. Press Enter after last element.
4. Press [Y=] to display Y= editor. Clear function Y1 and all functions or remove highlight from the = in Y2, Y3, etc.
5.Press [2nd][STATPLOT]1 to select 1:Plot1
The blinking cursor on ON means graph will be drawn. Type chosen is Scatter plot. Mark chosen is a dot.
Press [ZOOM][9:ZoomStat]
If you think that the curve look like a straight line you can try to do a linear regression.
Press [STAT] Arrow right to highlight [CALC]
Select [4: LinReg(ax+b)]
LinReg(ax+b) echoes on run screen. Press [2nd] L1 Press comma, Press [2nd] L2 press comma Press [VARS] Arrow right to select [Y:VARs][1:Function] [ENTER][1:Y1]
68a28f1.jpgENTER
That is the equation for the linear regression. As you see eqaution has been saved in Y1. Press [GRAPH] to get the data and the regression curve drawn on same graph.
Hope it helps.
Oct 04, 2009 | Texas Instruments TI-84 Plus Calculator
LinReg gives wrong results
probly because the calc was miscalibrated or someone screwed around with the variables...
hope this helps
May 09, 2008 | Texas Instruments TI-84 Plus Silver...
Linreg
enter your data into L1 as x-coordinates and L2 as y-coordinates at (STAT) + (EDIT) and then turn on your StatPlot. Finally, press (STAT) ->(CALC) -> (4)LinReg(ax+b) and (L1) (,) (L2) (Y1)
nb: Y1 could be find from (VARS) -> (Y-VARS)->(1:Function...)
Apr 25, 2008 | Texas Instruments TI-84 Plus Calculator
LinReg (ax+b)
just press (2nd) + (MEM)+(7) + (1)+ (2) and then try again.;)
Apr 23, 2008 | Texas Instruments TI-84 Plus Calculator
Line Regression
Hey I had this SAME PROBLEM!! Okay, here's the solution that FINALLY worked for me:
  1. Go to STAT PLOT (2nd, then Y=)
  2. Press "4" (PlotsOff)
  3. Press the ENTER button (it should say "Done" on th second line)
  4. Continue Graphing
I sincerely hope this tip helps!
Oct 25, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
1,478 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
