Question about Intel Motherboard
I865gvm-i motherboard i can not get a working avg graphics card to work on this board, i have tried disableing the onboard graphics, i have tried it with all on, i have set the right MBs in the bios for the geforce 6200 card and yet it still will not work.
This board has its video slot permanently disabled so you can only use the onboard graphics.  It's a cheaper version of the i865gm-i board.
Posted on Oct 16, 2008
    President:
  • 2,351 Answers
Enter your bios & make sure the video is set to AGP.
Your card has two VGA outputs. One VGA & one HDMI (high def). Switch your monitor cable that connects to the video output to the other femal connector at the Pc. You can do that while the system is running.
If that does not help think of this. You have been using the onboard video for some time. It must be dirty as heck. Remove the 6200 & blow it out with some canned air. No canned air. Use a clean paint brush & a sweaper. Than grab some alcohol & a cotton swab. Lightly dampen the cotton swab (no dripping). Wipe the copper retainer contacts of the video slot. Let it dry completely. Re-seat the card applying even pressure side to side till the card is seated firmly into the slot. Some cards require additional power. Check your 6200's install manual.
please vote...
Posted on Feb 18, 2008
  • Mike Peluso
    Mike Peluso Feb 20, 2008
    Try the 6200 in another system if at all possible. No listing for a board i865gvm-i but there is a listing for a i865Gm-I motherboard. Aopen. Fill in the first two windows under Download Center.
    http://download.aopen.com.tw/Default.asp...
Have a P5VD2-MX SE motherboard. Have tried to install NVidia GEForce 8400 GS but can't get it to work. Disabled on board graphics first but can't get any output.
it should working when you disable onboard graphic card on bios.
if not maybe some thing wrong when you attach that graphic card on VGA slot.
Mar 06, 2011 | ASUS P5VD2-MX SE Motherboard
Hi, I'm thinking about adding a GForce 6200 LE graphics card to the system, do I need to disable the on board graphics ? And how do you do that ? Thank You.
A Geforce 6200LE would work perfectly with that motherboard, all you have to do is clip it into the AGP8x slot and disconnect your monitor VGA cable from the onboard graphics and into the 6200LE graphics card. Once the Graphics card is inserted correctly and plugged in your sytem automatically disables onboard graphics as it is no longer needed.
Please rate me high.
Thanks.
Oct 31, 2010 | PC Chips M957G Motherboard
How to disable onboard graphics in D845epi so as to install Grpahics card? My onboard VGA is demage (not work)
When you power up the computer press F1 or F2 or "del" key or ALT +F2 then you can see bios screen.
Then go to advanced menu and disable onboard vga .
Then save settings of bios and exit.
Then your onboard vga is disable so you can install vga card into it.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 14, 2010 | Intel Desktop Board D845EPI Motherboard
Pci express will not work
Your N9600GT provides two HDMI out puts for dual display.
Even though you are currently only using one HDMI. Switch your monitor cable to the other HDMI out put. See if you now have display.
Also while in the bios allow, Page 2-27 in manual, Allocate IRQ to PCI set to [Yes]. Page 2-24, Internal Graphics Mode Select, [Disable]
Luck!
Mike
Oct 07, 2009 | ASUS P5GZ-MX Motherboard
MSI pm8m-v on board grapic
Onboard graphic will be disabled automatically if there is a graphic card in AGP slot.
Mar 19, 2009 | MSI PM8M-V Motherboard
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
Can you use a 128bit agp graphics card on a 32bit agp motherboard
yes install the drivers then under the device mgr disable the onboard video adaptor
Dec 19, 2008 | XFX GeForce FX 5200, Graphic Card
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
Replacing the onboard graphics card
Friend,
There are three PCI slots on yoyr motherboard. You can add any PCI VGA card to your board. After adding the VGA goto BIOS setup and make ON BOARD VGA DISABLED.
Thanks & Good Luck
Iqbal
May 27, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Gigabyte 7VM400M-Rev.1 Onboard Video
format ur computer once again.. n install the driver..
Feb 14, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Intel Motherboard Logo
121 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
