Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover floormate Hi, I'm not sure what the model number is on my Hoover Floormate, but I can't get the cleaning liquid to dispense. The vacuum(dry pickup works fine). The handle squeezes without a problem. It used to work without a problem and then I didn't use it for awhile. When I came back to it, it wasn't working. Thanks, Alissa
  • 2 more comments
  • ferdigirl Mar 01, 2008
    Hi reddevil6,
    I do believe it is the reservoir asm. The liquid dispenses when I manually push it in, but the sponge like pad(I assume this is part of or is the reservoir asm) does go down some when I squeeze the handle. Is there a way for me to fix it?
    Thanks,
    Alissa
  • clhp Apr 03, 2008
    I have the same problem, the cleaning solution doesn't reach the floor. I don't know where the problem is.
    1. I put a hose over the asm & blew thru it while working the handle. I could feel the difference in flow which seemed to be ok.
    2. I poured water in the asm & worked the handle. The water flowed out.
    3. I pressed the valve on the bottom of the reservoir & solution runs out very fast.
    When everything is assembled, water doesn't flow. I'm thinking something isn't aligned properly & the tank isn't quite touching at the bottom.
  • grizlee Apr 08, 2008
    Cleaning solution won't dispense.
    Plunger thing goes up and down'
    I put water in the asm? (the little black round circle) and the water does go down, but when I put the tank back on, nothing comes out.
  • Johnma Jun 08, 2008
    same issue.. clean solution doesn't dispense when i pull the trigger..
    President:
  • 1,673 Answers
The tank sits on what is called the reservior asm. it is actuated by the control rod inside the handle. With the tank off, watch and see if you can see that rod hitting the reservior asm when you squeeze the trigger. If it is moving up and down on it, then the resorvior asm may be bad. Also check the valve at the bottom of the tank, manually push it in and see if it releases water.
Posted on Feb 29, 2008
  • Lauren Junge
    Lauren Junge Mar 01, 2008
    You would have to replace it, they sometimes do go bad and that is the only cure for it.
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate h3000 w/spinbrush will not dispense the cleaning solution how can i fix
The hot glue trick will work; but what you probably need to do is gently push down on the black pin from inside the tank. This will lower the solution release mechanism and the solution will dispense. I found this solution on this website and it took 10 seconds and worked well.
Mar 31, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate does not disperse wet cleaning solution on the floor. brushes and vacuum pickup all work
First check to see that the wheel assembly is not broken. The assembly must move correctly to allow the fluid to be dispensed. Check for breakage at the rear of the wheel assembly where it attaches to the base. If this is not the problem, you may have a defective soap tank.
Jan 22, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
I have a hoover floormate h-2800 that does not suck up the water
this is a great vacuum. however it does require an extensive cleaning every now and then. diaassembly is required for this. there is a hose that goes from pick up to the tank. make sure this is clear. also your filter should be clean and dry.
May 20, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
My hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate h3000 not dispensing cleaning solution after sitting for extended time
check the seat valve on the bottom of the solution tank. should move upward freely. could be stuck if sitting for long period of time
Nov 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate won't dispense clean solution
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
May 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate 300 I lost my manual
here's a link to the hoover site with the manual for your machine :)
hope it helps
http://www.hoover.com/Product.aspx?model=H2850&ds=false
Jan 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Jan 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
405 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
