Question about Desert Spring DS3200 Humidifier
Can a class 2 transformer 24v, 12VA be used for DS3200 humidifie
My new furnace has a class 2 transformer 24V, 12VA. it is conntected to a drip humidifier. can I use this transformer to connect to my DS3200 humidifier which saves me changing the tranformer.
my email: fredrpittman@yahoo.com
  • 105 Answers
Depends on what Volts and VA your DS3200 humidifier works on. If it is the same, no problem but if it is different don't do it.
Posted on Feb 01, 2010
Testimonial: "thanks for the answer. I forgot to mention that the DS3200 has a stickers beside the motor with rating it as: 24Vac, 60HZ, 4 watts. "
How to wire the humidistat to the transformer
your transformer should have multiple wires on it. 2 of them are for 120 volt side hook up usually black is your hot 120 v wire and white is the common or neutral wire. on the other side of the transformer you have 2 more wires these are your low 24v side colors can range from red,green, blue, yellow ect. the wires for 24v dont matter about polarity or which one you hook up. one is 24v and the other is common.
Feb 08, 2013 | Aprilaire Humidifiers
I have no idea how to wire my Humidifier to the furnace! I am attempting to wire an Aprilaire Humidifier to an older furnace. The supplied wiring instructions are of no use to me because I have no terminal...
Hello, if the transformer you got with the humidifier is one that plugs into a receptacle than all you need is either a current sensing relay or sail switch. First connect one wire to transformer then connect to humidiistat then to either sail switch or current sensing relay and back to other terminal on transformer. if you use a sail switch then it will mount in the return air duct if you use a current sensing relay it will cradle the blower motors common wire. I will post a pic of both robhvac47_19.jpg current sensing relay
robhvac47_20.jpgSail switch
Feb 20, 2011 | Aprilaire 550 Humidifier
New furnace humidifiera class 2 transformer marked 24V, 12VA
The 24Va 12Vac transformer should function as well. with absolutely no problem.
Feb 01, 2010 | Desert Spring DS3200 Humidifier
I have a model G14Q3-60 Lennox Furnace. The make-up panel has 24 volts at terminal W1(heat demand) and common terminal T. Do you think the main 24v transformer can handle the extra load of the water...
You can add a solenoid valve without an issue. Most units come with a 40 VA transformer and that is usually double what the actual demand will be.
Jan 13, 2018 | Humidifiers
HOW DO I CONNECT TO 24 VAC FOR THE HUMIDIFIER TO
you can hook it to R and W on the board but you should really use a current sensing realy on the blower so it wont come on until the fan is running and you should also have a humidistat
Oct 04, 2009 | Honeywell Power Humidifier: Furnace...
Water runs when furnace is off, but stops when furnace is on.
the 760 humidifier does not need a transformer wired externally. the 760 has its' own 24v transformer inside the fan compartment. this transformer will provide the power to enrgize the water solenoid as needed. it sounds like to me the additional trasnformer is hot all the time. when the furnace comes on, the unit gets power and the internal transformer is cancelling the power from the external transformer. this would explain why it quits running when the heat is on. since the external transformer is hot all time, when the heat shuts off, the solenoid is getting energized by the external transformer. to make this run correctly, you need to get rid of the external transformer. leave the humidifier high voltage wires hooked up so they are only hot when the furnace runs. if you have a humidistat that has a r and c terminal, you will need to wire these directly to the r and c on the furnace control board and move the switch inside the humidistat to "power". make sure it is not on "bypass". then wire your 2 brown wires from the humidifier to each of the "h" terminals on the humidistat. if you have a humidistat that only has 2 terminals, wire one brown wire to each of the terminals. this should allow it to run properly.
Jan 28, 2009 | Aprilaire 700 Humidifier
Aprilaire 500A Do I need 24v transformer
if the funace has the 24 V you should use that but test it first with a call for heat to make sure it is 24 and not 120 coming out of that terminal!!!!!
Mount on cold air side with the bipass going to the supply.
Jan 17, 2009 | Aprilaire 700 Humidifier
Wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Dec 19, 2007 | Honeywell HE360A1027 Whole House...
Installation problem
I WOULD CHECK TO SEE IF YOU HAVE ENOUGH V/A OUT-PUT ON TRANSFORMER. I DONT KNOW IF YOURS CAME WITH ITS OWN TRANSFORMER. IF IT DIDNT YOU SHOULD HAVE A MINIMUM OF A 40 V/A RATING STAMPED OR PRINTED ON THE EXISTING TRANSFORMER. IF THE TRANSFORMER IS EXTREAMLY HOT ... YOU MAY NEED A 75 V/A TRANSFORMER WITH THE SAME VOLTAGES. INCREASING THE V/A CANNOT DAMMAGE ANYTHING IT JUST GIVES YOU MORE POWER WHEN EXCESIVE CONTROLS AND WIRING ARE ADDED TO A HVAC LOW-VOLAGE (24v) CIRCUIT. IF YOU LIKE YOU CAN CALL ME AT 727-363-7071. I AM A RETIRED HVAC&R CONTRACTOR WITH 45 YEARS EXPERIENCE. I HATE THE NEW SENSORS THEY HAVE TO ACTIVATE THESE NEW HUMIDIFIERS. I USE TO WIRE THE HUMIDIFIER TRANSFORMER (SUPPLIED WITH HUMIDIFIER) TO THE LINE (110V) SIDE TO THE LOW SPEED ON YOUR BLOWER MOTOR. THAT WAY THE ONLY THING THAT INTERUPTS THE CICUIT IS THE HUMIDISTAT. YOU NEVER WANT THE HUMIDIFIER TO RUN IF YOUR SYSTEM IS NOT "CALLING FOR HEAT". NEVER TRY TO ENERGIZE THE WATER SOLENOID THROUGH YOUR HEAT WIRE(USUALLY SMALL THE WHITE WIRE) FROM THE THERMOSTAT. THIS WILL RESULT IN BURNING YOUR HEAT ANTICIPATOR OUT ON THE T-STAT.
Jan 28, 2007 | Honeywell HE360A1027 Whole House...
Humidifiers Logo
422 people viewed this question
Top Desert Spring Humidifiers Experts
Paul Carew
Dennis
Are you a Desert Spring Humidifier Expert? Answer questions, earn points and help others
