Hi! I have a Whirlpool Duet front loading washer (model number WFW8300SW00)and I am getting an F-20 error code approximately seven to ten minutes into the wash cycle. What does this mean and how can I fix it?? Thanks so much for your time!!
  • eguthrie Feb 01, 2010
    Had the hubby check the water inlet hoses... Our hot was frozen.... This last load worked fine... (HOWEVER.... I wondered if one was froze and tried cold only and it still did it....). Once we thawed the hot line, it worked fine. Hurray! Thanks!
    Thanks so much for your time and help, Mike!! I appreciate it very much!!
  • 3,051 Answers
Hello here is some information for you Please read this . Try selecting different temperature settings. if it doesnt work , but it works fine on the cold setting
First check the hoses to ensure they are not kinked or the inlet screens are clean
If you open your machine,from the rear of the machine
There is a little blue plastic valve in the back, by where the water hoses come in. It has one yellow and one white solenoid, I believe, on it. this will need to be replaced
these valves will fail and give you the fault code that you are describing
Please that you unplug the machine before attempting any repairs to avoid getting a nasty shock or worse
Hope this is very helpful for you please keep me informed on how this is going
Best regards Michael
Posted on Feb 01, 2010
  • Michael Thomas
    Michael Thomas Feb 01, 2010
    kplease do me a favor and give my solution a rating this helps us get better solutions for our customers like yourself
    Best regards mike
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
Whirlpool front load leaking water from the detergent dispenser
Could be pressure too high reduce feed to machine only ....Slightly...Also try cleaning just in case its blocked
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Need a part number
The part number is W10160252. You can order the part at sears.com . The price is 131.10
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
