Question about Mitsubishi WS-55511 55" Rear Projection Television
I have a 55" mitsubishi rear projection hd tv, and when i am viewing hd channels,,,everything is fine, but when i go to a lower or nonhd channel the screen scambles and i can't see the picture. i tried changing and checking the inputs and it is the same on dvd and games ports. i unplugged the set and let it sit for a day or so then turned it back on and everything worked. i swithed channels and everything was ok. I played and dvd and game still all good...then i cycled tv power and the issue showed back up. it's like when it warms up it starts the issue on the lower def channels. please help. mogoto
  • Mitsubishi Master
  • 5,138 Answers
Replace Tuner on signal board. Call PTS 1-800-844-7871
Posted on Feb 01, 2010
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi TV having issues with HD channels
Unplug for a few then try it again you need to search channels again
Jan 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Is there a cable card in the tv which has to be as i cannot recieve HD channels, and i keep getting an error message about a cable card
Most of the time you will need an HD receiver to get the HD channels. If you already have one, it might be defective, or your TV may not be HD quality.
Sep 16, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
Apr 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
How to see local channels in HD with a traditional antenna?
If your set does not have an ATSC tuner, for HD, then you need to be using a suitably equipped STB.
Your satellite STB - box - should take in OTA channels and display them as part of its normal operation, tho. It takes in the antenna signal from your roof antenna and displays the HD version of your OTA channels, if it is an HD STB, along with the HD channels it gets from the satellite overhead.
Mr Bob
Dec 19, 2007 | Mitsubishi WS-65809 65" Rear Projection...
What do I need to do to get 1080dpi
Do you have HD cable or satellite? You need to make sure that they are connected to either a DVI, HDMI or Component (Y,Pr,Pb) connection. Depends on the age of the set you made need to get the Mitsubishi adaptor for HD. And to be correct the resolutions are listed as 48i,480p,720p or 1080i. DPI is used for printing or scanning as it refers to Dots Per Inch. In television we refer to lines.
May 07, 2007 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
