Question about Toshiba 50H72 50" Rear Projection Television
HD Receiver Describe your problem I am planning to acquire a High Definition receiver for my Toshiba 50H72. Is there an HDMI port in the rear of the unit? If there is not (the manual does not indicate that there is), how do I install the HDMI cable?
Ooble picture
Posted on Feb 18, 2008
I have my hd receiver amd am hooked up in the hdmi 3 port but cant get 1080p only 480p what do I do
Try moving to HDMI port 1, and possibly consider upgrading your Hdmi Cable. Yeah they get a little spendy but I upgraded my HDMI cables to the more expensive sony brand with the high speed connections and haven't had a problem since.
May 02, 2012 | Toshiba Televison & Video
Sky new zealand say my hd z70rx5 is unable to recieve hdcp even though the specs say the set is HDMI AND HDCP complient,they say no rear projection is able to receive hd is this true,any help i would be...
Terminals and Connections Dual HDMI digital inputs with HDCP (High Definition Content Protection) offer an uncompressed solution to the transmission and display of high definition video and audio content. All JVC HD-ILA TVs also include dual auto sensing component video inputs, assuring the best possible picture quality whether a viewer is using DTV, D-VHS or DVD, and three S-Video (two rear, one front) inputs and four AV inputs (three rear, one front).
hdmi.gif High Definition Multimedia Interface
HDMI is a new standard digital connection between A/V devices, such as a set-top box, DVD player or A/V receiver, and a digital television. HDMI offers exceptional video and audio quality with a single quick-disconnect connector. It supports multi-channel digital audio transmissions and component video color spacing for true rendering of HD video.
We carry a full line of high-performance HDMI cables. See them here...
Audio Features The JVC BBE High Definition audio system with Advanced HyperSurround and Active Hyper Bass includes two direct-drive speakers mounted underneath the screen for rich, expansive sound that fills your home theater or TV room.
Aug 06, 2008 | JVC Televison & Video
Toshiba Digital High Definition Receiver HD-C26H Locking-up
The problem is with the HDMI cable this some time make the receiver to lock try to use a RF cable instead this will fix the issue or try to use different video and audio cables mentioned in the manual .
to download the manual use this link: http://www.toshibaav.com.au/support/manual/Receivers/HDC26H.pdf.moz-screenshot.jpg
good luck............
May 05, 2008 | Televison & Video
I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Jan 12, 2012 | Denon Audio Players & Recorders
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
What is HDMI
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Mar 16, 2011 | Computers & Internet
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I bought HDMI cables for my 311 dish receiver and I believe the receiver doesn't have this feature.
This receiver does not accept HDMI cables or any other High Definition cables.
To receive HD content, you need to purchase an HD receiver with HD outputs such as component or HDMI.
As you can see in the photo, there is no HDMI output on this model, only composite (Red white and yellow) or S-Video (a now dead format)sheldon_j_w.jpg
Mar 07, 2011 | Televison & Video
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
Xbox connectivity problem
As dumb as this sounds here is the mistake Sony made. The receiver does not process sound from the HDMI, it will only pass through that data to you TV. So you will not be able to get sound from your 5.1 speaker setup if you only connect the HDMI, you have to use the matching audio input for that respective HDMI input. Make sense? So the HDMI DVD Input must have digital coax for sound, HDMI Video2 must have fiber optic for sound, and there is another fiber optic port for the Sat input. Yes thats right, if you have 2 HDMI HD components and each only has fiber optic(neither one has digital coax) you cant hook both up properly the way you would think. Sony made this receiver poorly, turning High Definition Multimedia Interface into High Definition Multimedia Except For Audio Interface.
Nov 18, 2007 | Sony STR-DG510 Receiver
Toshiba 50H72 50" Rear Projection Television Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
