Question about Hitachi Televison & Video
Hitachi SP50WS rear projection LCD TV screen has blue color strips on left half side of the screen. Other than that its ok. Do I need any adjustment or something serious or need any replacement. Thanks Iqbal
  • tv screen have blue lines. little blue dits. i replace my light. what to do model # ia v6h011857
Posted on Jan 22, 2011
  • Hitachi Master
  • 5,138 Answers
Model number you have Posted is not correct Look on back of TV for correct Model #
Posted on Feb 01, 2010
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Hitachi 43FDX15B distorted picture. The top of screen displays a half circle cirle and the image is distorted within the half circle. The same at the bottom of the screen. The middle of the screen is fine....
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 11, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Color blue will not adjust on crt color conergence adjustment , picture on tv is double with blue on right side, auto/manual mode , the color blue will not adjust on right or middle side from side to side,...
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | JVC AV-56WP74 56" Rear Projection...
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
I have a blue wave on my screen
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 61udx10b picture problem
Replace both of your STKs these are your convergence ICs STK392-110- use STK392-180s .
Dec 14, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Blue shadow
colored shadows indicate to me a convergence or focus issue. convergence issues can occur on one part of screen. and most recognizable around letters. this might could be adjusted by a technician
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 50+in rear projection tv
If you mean that the 3 colors (reg, green and blue) suddenly no longer line up properly in one area of the screen, it means that one of your convergence IC's has burned out and needs to be replaced. There is no adjustment that will correct the picture in this case. When I do a housecall to replace a burned out convergence IC and realign the convergence circuits, I charge $150 but shops in your area will vary so be sure to ask around.
Sep 18, 2007 | Hitachi 51F510 51" Rear Projection...
Blue Spot in top center of screen
same problem, guy said i need a COLOR DRIVE!! $1000, trying to find cheaper
Jan 07, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
335 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
