Question about Car Audio & Video
Alpine sub works for a bit then stops.
I have a 10inch alpine type-s, it has worked perfectly for the last year or so and now it'll work for a couple minutes when i turn the car on then just stops. I thought the sub itself might have been the problem so i exchanged it for a new one and the same problem occurs.
  • 1,068 Answers
The amp maybe going into protect mode. it may be seeing a fault internal and causing this. so i would have to say check all the wiring over and if that is okay you will need to take the amp for repair
Posted on Feb 01, 2010
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
I have an alpine MRP-500 amp that used to work great with my 2 10" Type-R subwoofers. Out of nowhere the sound just stopped working and still will not. I had the amp and subs tested and the guy said it was...
  • make sure the subwoofer level is up on the head unit.
  • Make sure the RCA cables are good.
  • Make sure the remote wire is connected and has 12v+ when the head unit is on.
If the remote wire is not turning on the amp, its not going to work. To hot wire it to see if thats the problem, just run 12v+ to the remote jack. That will turn on the amp.
Nov 22, 2009 | Alpine MRP-M500 Car Audio Amplifier
Subwoofer stopped working
Put another known working speaker in there to see if it works. If it does then the issue is with your speaker. If it also does not work your amp is to blame.
Sep 16, 2017 | Alpine SWR-1222D 12" Type-R Series...
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Has my subwoofer been blown?
hook ithe sub up to a 9volt battery and see if the woofer moves... You will not dammage the suub testing it this way.
Mar 23, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Weak output from sub..
The woofer was not demagnetized.
If one signal cable is damaged, it could reduce the signal getting to the amplifier and could reduce the output.
Plug one RCA plug in at a time to confirm that both are working properly. If one is lower or not working, the cable may be defective.
If both work properly, double-check the settings on the head unit (sub-out, bass, crossover frequency...)
Oct 28, 2007 | Alpine MRP-M350 Car Audio Amplifier
Just died out..
Have you determined if the problem is with the amplifier or the subwoofer?
Have you checked the wiring to make sure that there are no loose connections?
Oct 18, 2007 | Alpine MRP-M450 Car Audio Amplifier
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
