Question about Canon MP560 All-In-One InkJet Printer
MP560 dispays failed to connect to access point
Without Disc how can I connect a CANON MP560 printer to the computer ?
go to the cannon support website put your data and for your printer and download the drivers for your printer on to your computer. space
Mar 05, 2015 | Canon MP560 All-In-One InkJet Printer
Unable to browse to cisco access point
'192.168.0.116' is the wrong range for the router. The Cisco manager allocates the ranges the router will use.
See this page on the setup.
Getting Started Guide Cisco 3700 Series Access Points
May 28, 2014 | Cisco Computers & Internet
Canon mp560.. I have replaced the head and it is still printing blank pages. Is it something to do with the purge thingy??
Try accessing the menu on the printer and it should have some printer options that you can use to tell the printer you installed a new cartridge
Jul 01, 2011 | Canon MP560 All-In-One InkJet Printer
Hello, im trying to install my wirless printer to my wireless computer and im having some difficulties. for example its asking me to check my wireless LAN access point.. I dont know waht that is? im...
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
May 16, 2011 | Canon MP560 All-In-One InkJet Printer
Cant connect on NIMBUZZ. connection always failed
You may having problem with your internet setting, please check your access point.
If access point is ok then, go to nimbuzz app. > option > app. access > communication > network access > and make it allowed.
hope your problem will solved
thank you.
Apr 21, 2011 | Nokia Classic 2700 Cell Phone
I have a micromax q3 handset but whenever i open opera mini after loading it says failed to connect to internet ....i am unable to access internet plzz suggest me...i have bsnl connection...
You need GPRS settings for it, install these setting set them defualt, restart you mobile try connecting, if it still dosen't work check network settings in your mobile I dont know where is it in your mobile, search it , check the access point is ok, the access point shout be same that you get in massage, each network operator has defferent access point.
Mar 08, 2011 | Opera Software Browser
Ps3 help
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Confirm that an Ethernet cable is not connected to the PS3™ system.
3.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings) in the home menu.
4.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
5.
Select [Easy].
connectwired002.jpg 6.
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
connectwireless002.jpg 8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
connectwireless003.jpg 9.
Check the SSID for the access point.
10.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
connectwireless004.jpg 11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
connectwireless005.jpg When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12.
Save your settings.
13.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
14.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Hints
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to work with my wireless broadband
Settings > Network Settings > Internet Connection Settings (wireless connection)
Internet Connection Settings (wireless connection) This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
1.
2.
3.
4.
5.
Select [Easy].
Select [Wireless].
Select [Scan].
10.
12.
Save your settings.
13.
14.
Hints
Mar 12, 2008 | Computers & Internet
Canon MP560 All-In-One InkJet Printer Logo
666 people viewed this question
old marine
old marine
