Question about Ovens
Whirlpool gold accubake oven won't re-ignite
Hello, I have an intermittent problem with my Whirlpool Gold Accubake oven (Model #: GS440LEMQ). During the normal course of baking the oven will obviously re-light many times to maintain the set temperature. I have a situation where sometimes the oven will begin to lose heat and never re-light. I can tell when this is about to happen because I'll see the "HEAT" indicator come on, then I'll hear the ignitor start clicking along with the gas coming on. After about 5 clicks, the gas shuts off. After a couple of minutes, it will cycle through and try again. Eventually, it will stop cycling throught the ignition process and just give up completely. At this point, I hit "CANCEL" and wait about 15 mins. to turn on the oven again.
When everything is working, I'll only hear 1 or 2 clicks and then the gas continues to flow (based on the "hissing" sound). It almost seems like the oven realizes that its not getting a good ignition, so it gives up completely.
The rangetop works fine.
Any help would be appreciated...Thanks.
  • 1 more comment
  • IKES48 Mar 22, 2008
    I just had the same problem with mine.Different model( whirlpool though),but doing the exact same thing.Here's what I did & it worked:
    Take the inside bottom cover off.There are 2 screws toward the back of the oven.Next,take the burner cover off.2 screws up front.
    Now you'll see the burner & ignitor.Turn on the oven.Watch the burner holes nearest the ignitor.If any are clogged,they won't ignite or will only partially ignite.My stove isn't that old & just one was partially clogged,but I cleaned it out,& everything works perfect.Another words, the gas is having trouble getting to the spark to ignite & these stoves are made to shut down after a few seconds( I think 4) of trying.by the way,I used a small reamer that is used to clean the tips on welding torches.I would be careful not to make the hole bigger than it's suppose to be or you'll have a bigger flame there than the rest & uneven heat.
  • Carol31346 Nov 27, 2008
    This oven came with the house I bought and the previous owner said she never had a problem but everytime I try to bake something for a long period of time - it is okay for a while then it turns off. I had this problem with a turkey and when I went to baste it, the oven was barely warm but the panel showed heat on and temperature at 350 degrees. When I first turn the oven on it sounds like the gas is coming on every so often which seems odd to me but I was told that is how this type of oven works. Another problem I have found is that foods don't seem to brown as well as in other gas ovens I have owned. It is very frustrating when you are cooking a meal and the food should be ready and isn't. At this point I would not recommend this oven to anyone!!
  • Anonymous Mar 27, 2014
    Oven does not heat up, clicks two times
I have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Posted on Nov 02, 2008
I have the same problem. the oven had this problem when still less than 1 year old but i did not realize it.
Posted on Aug 04, 2008
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
How do i set clock and keep it displayed on a whirlpool gold accubake oven
http://whirlpool.custhelp.com/app/chat/chat_launch will give you a chat line where the Whirlpool expert will chat with you and help you get your problem solved
Nov 07, 2011 | Whirlpool GBD307PDS Electric Double Oven
My Whirlpool Gold Accubake, smooth top displays E1 - F1 (blinking). I am unable to utilize the oven because the push-button/ touchpad does not work however the electric burners work fine. Any clue? Many...
Hello, Thank You for using FixYa. I will be helping you today.This is erc or control failure. You would have to replace the electronic range control sometimes called the clock depending on your model number
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Whirlpool Ovens
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Gold Accubake gas oven will not heat up?
If you can see the ignitor coming on and it is not very bright then it is most likely weak. Check out my handy GUIDE
Jun 14, 2009 | Ovens
depress the broil button for 5 seconds it will revert back to Farenheit
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
1,691 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
